Old 09-23-16, 12:25 PM   #721
creeky
creeky's Avatar
Living in the country I have a lot of wasps.
For keeping wasps from building nests you can buy "fake" wasp nests that hang in the room you wish to keep wasp free. They work pretty well.
The other thing I do is identify which kind of wasp is nest building. Most paper wasps are harmless and build very small nests with only a few individual wasps using it. They're cute. Not cuddly. But I leave them be.
The European yellow jacket is a great predator. Keeps the bugs outta my garden. Unfortunately they can build huge nests and the numbers really get outta hand. I have used boiling water to kill the queen. They do get aggressive late August when the queen cuts them off of food. Only the queen survives the winter. The workers all starve and she starts again in the spring.
Wasps are very effective at controlling thrips, flies, etc. So I try to take a win/win approach with them. I leave them alone to keep my garden clean.
Current projects
Old 09-24-16, 12:51 PM   #722
I use brake parts cleaner. The stuff will knock out wasps and yellow jackets, but bumblebees and honeybees survive. Also, any overspray just evaporates. It doesn't linger around to poison or taint the plants.
Old 09-29-16, 02:03 PM   #723
Tilapia eating lunch
Old 10-10-16, 12:45 PM   #724
Hurricane was close enough to give us some wind on Saturday. (We are a long way from the main storm.)
We lost power for about three hours. My backup 12v air came on. This was a good real world test. When the power came back on the 12v air kicked back off.
I did take the bell out to keep water in the grow bed.
The fish were fine and this backup system gives a piece of mind.
Here are some of my young lettuce starting out.
Old 10-17-16, 09:40 AM   #725
My tomatoes are getting blossoms now that it has cooled off some. I have green tomatoes coming. I still need to trim them up but those tomato plants are nine months old.
My nitrates are strong so I am trying get a good crop lettuce growing.
This is my first time growing head lettuce.
We are getting tomatoes every day now.
ID:	7308   Click image for larger version
ID:	7309   Click image for larger version
ID:	7310   Click image for larger version
Old 10-21-16, 04:17 PM   #726
Hydrocyclone to oxygenate water http://ecorenovator.org/forum/49721-post649.html
I adjusted my vortex oxygenator.
I took 1’ piece ¾ pex put down the inlet and I took a second ½ piece of pex in the inlet. I will take a picture later.
But the air flow had slowed down. With this new change the air flow looks great again.
Old 10-24-16, 11:14 AM   #727
My lettuce is coming along. I need to redo my air to the deep water culture. Maybe that is why some lettuce is doing better that others planted at the same time.
This is the same picture as above this post just 7 days later.
http://ecorenovator.org/forum/52105-post725.html
I have been starting lettuce each week. I would like three heads started each week.
Last week I started three heads but only two came up.
So this week I started five and all five are coming up. I guess I will try four next week.
I have been just soaking the rock wool and putting the seed in it. Then I just put it in the DWC bed. So no transplanting at all.
ID:	7326   Click image for larger version
Old 10-26-16, 10:19 AM   #728
Here are the plants. I pick a few tomatoes every day. There lots of tomatoes coming.
Lettuce coming along.
I have 19 heads of lettuce started most very small but each batch started a week apart.
Same plants 17 days later. I am not sure if it is growing as fast as I thought it would.
I still need to fix my air in the beds and I just ordered 1,000 red worms. I will put most of the worms in the DWC beds.
ID:	7328   Click image for larger version
ID:	7329   Click image for larger version
ID:	7330   Click image for larger version
ID:	7331   Click image for larger version
Old 10-28-16, 08:23 AM   #729
I made an air manifold for my DWC I just need to add a couple more air stones to the bed.
My worms are coming next week so I want to get some more air in the bed for them and the plants.
I used an 11/32" drill bit, 1/8" tap and 7 x 1/8" air valves. I taped a 1/4 hole into end to connect my airline with a standard 1/4 air hose connector.
I adjusted my vortex oxygenator hopefully one last time.
But it is really dumping out the air now.
Daox (10-28-16)
Old 10-31-16, 10:13 AM   #730
I am going to try this out. using polyurethane foam as seed starter
Using polyurethane foam as seed starter
Hobby Lobby foam.
Here are three of the four types of the tomatoes we are growing.
There are other people using this on a larger scale.
Over the weekend I planted a couple seeds in rock wool and in foam. This is a test to see if the foam I bought will work. I like this idea and it is much cheaper than rock wool.
The lettuce really took off since I added more air to the bed.
If they look a little thinner they are I have not waited and have picked some lettuce for a couple sandwiches.
ID:	7338   Click image for larger version
ID:	7339   Click image for larger version
ID:	7340   Click image for larger version
ID:	7341   Click image for larger version
