10-31-10, 01:56 PM | #61 | |
10-31-10, 04:53 PM | #62 |
Good point. I avoided putting it on the top due to dust settling on it. Perhaps on the side would be a good compromise. I was thinking of attaching it with some sort of channel so you could just slide it in and out.
11-03-10, 12:47 PM | #63 |
Instead of having the filter under or on top cut the side at an angle and add a lip to hold it in place. So instead of the left hand side being an L with the filter at the bottom make it \ with the \ being a filter.
11-03-10, 09:53 PM | #64 |
Hi,
This one requires a "small" modification to your attic roof, but it appears to work well: IWillTry.org Build a Solar Attic ----------- I wonder how well the attic would do as a heater if one eliminated the attic ventilation and did some form of simple insulation on the north facing part of the roof. I realize the attic ventilation is there for a reason, but if one could get worthwhile heat from the attic, maybe it would be worthwhile having forced attic ventilation controlled by sensors that only ventilate when the attic needs ventilation (maybe when the humidity is too high?). Seems like there ought to be some simple way to turn an attic into an effective solar collector? Gary |
11-03-10, 11:30 PM | #65 |
Very good points Gary. I agree the attic is kind of a perfect but less efficient solar collector. You might as well use it for something. My first idea was just to run some pex tubing up there to act as a hot water preheater. You'd have to drain it during winter of course. But, that would be a very inexpensive option. This blower idea came a bit later, but I think it will translate into more energy captured vs the water preheating.
I really like the idea of closing off the attic vents to capture more heat. It would be quite interesting to see the effects this would make on how hot the attic gets.
11-08-10, 11:20 AM | #66 |
Wouldn't make sense to put a heat pump in the attic? This would "recirculate" at least some of the heat back into the house.
The vents are needed to let moisture out. If you have a nearly perfect vapor barrier in the ceiling, then you could close them off. |
11-23-10, 09:47 AM | #67 |
this thread is too informative. It gave me some ideas. thank you all.
11-23-10, 10:26 AM | #68 |
I'm thinking that you should be drawing air from near the top of the attic. As I see it, as the air is drawn from near the attic floor cooler air will be drawn into the attic via the soffets. Then the fans will be pushing that cooler air into your house.
11-24-10, 02:02 PM | #69 | |
If you're going to do this, it's important to vent the output from the "outside" unit of your heatpump out of the attic, otherwise your attic will become much colder than ambient in the winter and much hotter than ambient in the summer. These conditions wiould be undesirable. -AC_Hacker |
11-24-10, 03:34 PM | #70 |
delete... double post
Tags |
attic, heat, reclamation |
