#651 |
![]() Congratualtions on 100k hits!
Neat thread. My first time here. Glad to see a nice group of folks not intimidated by the so-called pros, nor inundated by the 'ha-ha' type of know-nothings untalented 'pros' - as exhibited in some of the early posts. probably more buried in the thread, which I have not read thru. Happened by here as was posting about my DIY GSHP on a greenbuilding site and had fun throwing back the cr@p at retailers and salesmen who claim DIY HP is 'impossible'. It aint rocket science after all. I built my GSHP from scratch for under $1000 -- $300 of that was for a new closeout copeland scroll, $70 for refrigerant (next one will be BBQ propane, another topic), $100 for welding rod, etc. to build a percussion drill rig on the back of my dozer, various other tidbits, etc. Heat my 5300 sq ft house (another DIY project) with it totally. HP Evaporator is tube in tube made from all surplus pipe (cleaning techniques a story all by themselves too) , condensor a salvaged 7-1/2T carrier coil, all homebuilt controls, etc. Might retire this year, and will post some details as a how-to for others then when time available. The $1000 DIY HP has a COP of 5.6 at 9.5 gpm water flow, I get 58,000 BTU/Hr output from a nominal 4T scroll compressor - trouble free operation since built in 2009. Keep up the good work, there are only a few folks out of 100 who are willing to learn and do as you are, we need to keep encouraging others! |
#652 |
You Ain't Me
![]() Good God! Please post a lot more information about this project! Please start a thread or something so enlighten us! How did you drill? How deep? Haw many wells? How did you hack the compressor? How is it controlled?
You guys rock. |
#653 |
Renovator-in-planning
![]() mejunkhound,
I would love to hear more about your hacked Heat Pump. I happen to have several air conditioners that would make great "donors" as they say in the DIY Electric car groups. One is new in box, 1 year old. Two others are 1 and 2 years old.... and another one has a bad blower motor. As far as I can tell, the compressor works. |
#654 |
![]() This site looks like a good site to start a separate thread when I have time (may not be till I retire later this year)
Think there is a pix attached if attachment tool worked, LH is control box, 100% DIY from garage sale 'finds', RH pix is how to build your own 5 Ton evaporator with scrap pipe (cleaning the insides of old Cu pipe to use on HP involves ferric chloride, HCl, etc) Used 70 feet of 3/4 Cu pipe inside 1-1/4" PVC for HP descriped in #650. DIY well drilling (long story) but ended up using the cable tool method as had to go thru a few 3 ft dia basalt boulders - used up most of a '72 datsun and '64 GMC truck and parts of '62 Chevy to build the drill rig. edit BTW - the 8-ball is to signify DIY 'denigrators', heh, heh.... Have fun. |
#655 |
![]() Good job mejunkhound
![]() I can't wait to see the details once you start the thread.
Ecorenovation - the bottomless piggy bank that tries to tame the energy hog. Last edited by Piwoslaw; 04-06-11 at 10:19 AM.. |
#656 |
![]() Congrats on the 100k views ACHacker! You've done an amazing job with your heat pump and I'm glad to see so much interest in the topic. Thanks for sharing with all of us!
I also agree with the others, it would be great to hear more about your project mejunkhound.
#657 |
Uber EcoRenovator
![]() New to the thread enjoying very much.
AC good work. I live in Canada, Ontario in the countryside with a lot of wind. We used to heat a 3400sqft home with oil. OUCH. The home I built in 1997 was on-grade concrete slab with in-floor heat and great insulation. Very efficient and comfortable. We had changed to a comercial GSHP suplimented with solar hot water to heat the floor. Now the cost to stay warm in Canada is easier to live with. Next I will try to build my own GSHP for my shop 1600sqft. I will be converting a 2.5T air cond. and direction from your thread. Half the shop already has in-floor But the balance of the concrete will have to be torn out and installed with PEX. I have found with the solar hot water suplimental that a heat exchanger (HX)/copper coil built inside a hot water tank is not as effective as a counter flow brazed plate HX. After all the heat transfered to the water in the tank is by gravity off the copper coil. Looking forward to hacking the AC |
#658 |
![]() Welcome to the site Randen.
I'd love to hear more about this project. I too wish to tear out my garage floor to put in a heated floor. I'd love to see how someone else handles the project.
#659 | |
![]() Quote:
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Sorry to not get back to you sooner, but I had a serious accident on my electric bike, broke my arm in six places, endured two surgeries and will be laid up for some months. All projects on hold for the time being (ALL MY BASE ARE BELONG TO THEM). My typing has always been slow, now it's slower, but I can still type. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Almost all of the mini-splits use "inverter technology" which means that the incoming AC is converted to DC, then re-converted to AC at varying frequencies, which makes for variable speed compressors and V.S.fans, and a big gain in efficiency. You are quitie right about economies of scale and minisplits. If someone who had a good technical background in circuits & programming could "break the DNA code" on minisplit construction, it would be a tremendous boon to the HVAC DIY community. Maybe you're the guy? As of this writing, there are few options available for high performance, inverter technology Air-to-Water heat pumps. ...this is one that is way good and way expensive. But it sounds like you are interested in air or water in and air out, right? I found a document about this kind of thing, only on a larger scale. They're suppose to be a very good compromise, maybe the best. At any rate, I started a thread on mini-split hacks, because Xringer seemed to be interested in it. Good luck, -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 06-07-11 at 02:00 PM.. |
#660 | ||||
![]() mejunkhound,
Welcome aboard! Quote:
Tags |
