12-08-17, 10:42 PM | #651 |
DIY Geek
My 4.4kW system November data:
2017: 448 kWh 2016: 423 kWh 2015: 415 kWh 2014: 415 kWh 2013: 368 kWh |
12-09-17, 09:36 AM | #652 |
Nice that was your best November yet.
12-26-17, 04:39 PM | #653 |
We are getting closer to 5 years solar data.
This graph has production broken out by season. I found it interesting
12-28-17, 04:08 PM | #654 |
Today I installed my replacement Enphase M215. My array is back to producing at full capacity again.
I just need to put my prepaid label on the box and send back the bad microinverter. It was still working but it was about 20% off all the others.
01-02-18, 12:53 PM | #655 |
12.5 kW array we generated 997 kWh Dec 2017
We used a lot of power this month. Dec 2017= 997 kWh Dec 2016= 924 kWh Dec 2015= 911 kWh Dec 2014= 996 kWh From my calcs we have used up our banked power. we have 126 Kw banked left We have used up our banked power for the year. Our solar year resets March 1. The first time and like 3 years I fired up my NG heat. It is really cold here last night it was 6 degrees F for SC that is cold. We will be switching for NG heat to Mini split heat depending on outside temp until our solar year resets. Why we ran out of banked solar power this year. We made 851 Kwh less this year. We drove our car much more over the summer. My son got his learner permit and drove our car more over the summer to learn to drive. I had a microinverter making 20% less power I have replaced it. We just were not a careful with usage. When you surplus each year you don’t watch your usage very closely Here is a yearly chart. Other solar producers show us your numbers when you have them.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 01-10-18 at 10:26 PM.. |
01-02-18, 06:02 PM | #656 |
For December 2017 my array produced 638 kWh. My household consumed 676 kWh, so we're close to breaking even. Considering it's a low producing month due to winter conditions I'm totally ok with that!
DIY installed a 9.98 kW rooftop solar system with REC TP2 panels, SolarEdge SE7600a-us grid tie inverter, power optimizers, & Snap 'N Rack mounting system. |
The Following User Says Thank You to antdun For This Useful Post: | pinballlooking (01-02-18) |
01-02-18, 09:51 PM | #657 |
DIY Geek
My 4.4kW system December data:
2017: 442 kWh 2016: 377 kWh 2015: 322 kWh 2014: 422 kWh 2013: 359 kWh 2017 Annual output= 5,960kWh 2016 Annual output= 5,801kWh 2015 Annual output= 5,856kWh 2014 Annual output= 6,388kWh 2013 Partial Year (Aug 1 to Dec 31) output= 2,334kWh |
01-02-18, 11:20 PM | #658 | |
01-05-18, 08:16 PM | #659 | |
DIY Geek
As I look at current prices on equipment, I keep thinking I should install a ground mount grid-tie array. I just saw where my power company is going to build two more PV farms. |
01-10-18, 10:50 PM | #660 |
This is our power bill for the last two years.
Keep in mind we also use this power to drive our car 20K EV miles a year. It is just the meter fee unless - then it is them paying me Total is $91.34 for two years. We drove our car 40K EV miles in this time. All AC and heat was electric during this time frame.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 01-10-18 at 11:43 PM.. |
The Following 2 Users Say Thank You to pinballlooking For This Useful Post: | davidmiller (01-16-18), gasstingy (01-11-18) |
