Old 11-14-13, 01:29 PM   #51
Are they asking for the broken unit back? If not, have a go at fixing it yourself. Sounds like a pipe rubbed through/cracked and started leaking.
Old 11-14-13, 01:37 PM   #52
workaholic
So far they are not. And that sounds like a good idea. Thanks
If there are two ways to do a job always choose the hardest; it'll take twice as long but you will learn twice as much.
workaholic is offline   Reply With Quote
Old 11-14-13, 10:46 PM   #53
http://hometips.me/Mar/GE-heat-pump-...anual-2009.pdf
Quite a bit of interesting info. It uses two Delta evaporator fans with Cindy Wu sensorless FOC (more or less the same as what I'm using in my design!) and a TXV, but oddly seems to use a refrigerator compressor instead of an air conditioner compressor. I presume that is because a refrigerator compressor does better with large compression ratios, with the controller constantly monitoring the compressor current draw (with the Hall sensor) and dialing back the fans to prevent compressor overload. That can be quite a bit at higher ambient temperatures, hence the (relatively) poor efficiency compared to a cheap window A/C.
