08-26-12, 04:23 PM | #51 | |
Home situation is more normal. Ground Source heat pump working fine. GH |
08-26-12, 09:52 PM | #52 |
Turning my living room Sanyo off and on by remote control is very easy for me.
I have an X10 AC module providing DC power for my 10A power limiter unit. The off signal to the X10 disconnects my Sanyo from the 240ac. That's the nice thing about using the IR remote. I could switch off the power and it would look like a grid fail to the Sanyo. Once it came back on, the Sanyo would boot up in off mode. But the remote would send it's command stream (within 5 minutes) and bring it back to where it was, before the power loss.
08-26-12, 10:07 PM | #53 | |
This is a topic that has tremendous potential in many different ways. The most compelling reason for me is that the mini-splits are so efficient, and also, if properly designed, hydronic radiant floor heating systems can be very efficient, and the efficiencies of both together would work together in a very desirable way. I don't know if you followed the thread, but Acuario did some very interesting work along this line and, as far as I can tell, was successful in cracking the code on a converted Daikin AC, which he had turned into a heat pump. He was generous in sharing his progress, but I'm afraid that the trail he left was not marked well enough for a determined newbee such as myself to follow. I suspect that each manufacturer implements the communications between the inside unit and the outside unit somewhat differently, but I'm pretty sure that the manufacturers are most probably making their designs from a very small pool of specialized ICs that are made specifically for this application, so there are bound to be core design similarities. Any information on this topic of inverter system communication will be most appreciated. Best -AC
08-27-12, 10:15 AM | #54 | |
CAN use internet as I have a 2.4GHz wireless link to the unmanned building. (trying to get to 10 posts so I am allowed to PM) |
08-27-12, 10:25 AM | #55 | |
So my request is more for information more along the lines of the interface used for optional wall 'thermostats' or controls (one is called a digital control unit). The 'remote' building is an aircraft hangar at the airport. I already use an small embedded processor to monitor hangar temperatures and such and want to add an interface for the heat pump. GH |
08-27-12, 11:04 AM | #56 | |
My little CAI controller can do X10. The data format is built in. http://ecorenovator.org/forum/applia...html#post17319 I've used the CAI board connected to an old wireless router and was able to easily control X10 devices, using a portable wifi tablet.
08-27-12, 12:09 PM | #57 | |
08-27-12, 12:24 PM | #58 | |
X10 is just one idea. If your mini-split works like mine, using the remote to recover after a power loss, then you can use any method you can find, to control the main power to your mini-split.. Is there a phone line to the site?? 3-Relay Touch-Tone Remote Controller - RC3 - Shop now - Black Box There are many ways to skin a cat..
08-27-12, 12:36 PM | #59 | |
What I am hoping to get from the forum is some details on the wired interface to the inside controller board, so that I can integrate it into my already existing web based monitor/controller. So, to repeat my request, is anyone willing to share the details of any wired interfaces for optional wired controls for the mini-split heat pumps; where wired interface is to the inside control board and not hacking into the inside-outside control link. The Sanyo series offer an optional wired controller and the YMGI advertises one that cannot be ordered. Also CadillacKid's postings imply the most of the unit built by Chigo also have it and he has interfaced to it. Details on that please! GH Last edited by grayhawk; 08-27-12 at 08:30 PM.. |
08-30-12, 11:01 AM | #60 |
Sort of a bump on this topic, and also to get me to 10 posts so I can PM.
It's not a good idea for me to use X10 in my hangar (where the mini-split heat pump is located) as the power wiring is shared with 5 other hangars. I don't want to go to switch my AC on or off and accidently turn on or off the engine warming plate someone else has installed on their expensive aircraft engine. The safest and easiest method to me, still seems to understand the interface used for the optional wall control and then integrate that into my existing web based controller, one that I have written the code for. It is currently monitoring temperatures and other sensors within the hangar. Thanks for an information as to this specific interface. GH |
