07-09-20, 12:12 PM | #41 |
Our latest product is a protector for the fan/filter protector for massey ferguson GC 1723 ans 1725 tractors.
There is a plastic hydraulic fan behind this a stick can take it out. There is also a hydraulic filter behind this. You can connect the Mid mount mower without removing the protector.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 07-09-20 at 07:58 PM.. |
07-22-20, 10:45 AM | #42 |
Our new product is the best selling product so far. We are very happy with it.
My other work has slowed down with the virus so this work is welcome right now. My son has made enough money for his first-year collage. He is staying at our place at the lake and he has some scholarship money. But he has earned enough to pay for the rest for the first year. We have made enough to pay for all the equipment. But I just added more equipment. So it will be a little longer to have it all paid off. One sheet 1/8" plate 770 pierces 2,729” inches. About 45 min to cut out. I have added a Hypertherm powermax 85 it will cut and pierce ¾” plate. Edge start 1” plate. 45 amp 100% duty cycle. So far, this thing is sweet. It has fine cuts for 10 gauge and under. My old cutter I will keep for hand cutting and a backup for this cutter. Now you can see why I need more lifting capacity and why I bought the old front end loader.
07-22-20, 01:22 PM | #43 |
Sounds like you have found a very rare thing . A product ( toy ) that will pay for itself ! :-)
Enjoy yourself , my friend . God bless Wyr |
07-27-20, 01:49 PM | #44 |
Here is my new plasma cutter cutting ½” plate @85 amps.
This is more than twice as fast as my old cutter and the cut it better on top of that.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 07-27-20 at 02:58 PM.. |
07-27-20, 02:28 PM | #45 |
God bless Wyr |
10-28-20, 12:43 PM | #46 |
Quick update All equipment is paid for and we made our first 5K profit. (after all cost and equipment paid for)
It has taken a lot of work getting here and I keep adding more equipment. At this point I have the equipment I need time to make it work. It has been quite a ride. We have shipped 263 tractor accessories out so far.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 11-01-20 at 10:41 AM.. |
