Old 01-07-14, 12:28 PM   #41
Yeah, I've already seen a problem. The MTUs must have some drift in their clocks.
(I can see their RTC are off)
The updating just stopped on both units. I looked at the transmit lights,
and they were synced up.
(Both transmitting at the same time, jamming each other).
I disconnected the power into the new one and restarted it out of sync.
Now both are working again..
I may have to figure a hack, if these things keep getting into sync,
and don't drift out of sync in a few minutes..
Old 01-07-14, 12:35 PM   #42
Do you have the power to each MTU on a different leg of the 240? They talk on that leg so they won’t jam each other if they both are on different legs.
Old 01-07-14, 01:04 PM   #43
I have so many LEDs (with a few CFLs), a TED won't run very well on any circuit.
Too much noise on the lines. So, I used a filter to make one 'Clean' outlet, (120V)
and wired the MTU power to that outlet.
The 'Hot' line that powers the MTU, is also the signal output line for the MTU.
That's the only way I could get my TED to work.. But now that I have two TEDs,
I'm trying to run them both off that single clean power source, and driving their signals onto the same line..
Old 01-07-14, 01:47 PM   #44
Sounds like you need another filter for the power wire for the second TED MTU so they can talk on their own hot wire. This is also what TED support suggested that would work.
Old 01-07-14, 02:11 PM   #45
Default Trying a Hack now..
I'm trying a Firmware solution. Not sure but this might work.
Page 11 of the manual has some info on setting up for Two MTUs..
(For TED model 1002, not for these 1001 models).
When it asks, "How Many House Codes", I selected two.
I left the second house code as 000. (I set both units like this).
I went down and turned off the Den MTU.
The LR MTU xmit LED is flashing once per second. (60 transmissions per minute).
When I turned on the DEN MTU, and it booted up, a nice thing happened.
The MTU xmit LEDs slowed down to 40 per min.
And, they are perfectly out-of sync! One is on when the other is off.
The are switching perfectly now, like a see-saw or flip-flop..
The line is seeing 80 transmissions per min, 40 going to each RDU..
Just having one of the TEDs set for 2 MTUs seems to get the 40 per min
sync mode started.
These things seem to be talking to each other..
I hope this just isn't a fluke and they stay locked in flip-flop mode..
Old 01-07-14, 02:25 PM   #46
Cool. I asked them about using a TED 5000-G and the Ted 1001 so it could be different.
Old 01-07-14, 02:41 PM   #47
Default Two for TED or TED for Two?
Dang! They synced up again!
I figured selecting dual MTUs would turn on a Listen-Before-Transmit protocol.
But maybe having them both in the same mode doesn't last..
If one clock drifts, they might both listen and hear nothing,
then both transmit at the same time..
Maybe just telling one TED there is 'another', will set up a master-slave
condition and one TED will sync itself to the other..?.
Trying it out now..
Edit: 1/8/14
The TEDs still locked up (both transmitting at the same time), with the old TED set for two MTUs.
So, I had one more thing to try. I set the old TED back to one MTU, and set the new TED for dual MTUs.
It's been running perfectly since yesterday. We have not seen one lock-up.
One odd thing was noticed on the MTU flip-flop cycle. It only happened for a short while,
then went back to normal. The old MTU xmit LED was flashing twice (quickly),
before staying off, while the new MTU flashed once. (Then the 2-1 cycle would repeat).
It worked fine. Just looked odd. Now it's the plain old flip-flop cycle..
Last edited by Xringer; 01-08-14 at 11:27 AM.. Reason: Updating the MTU flip-flop cycle
Old 01-10-14, 05:38 PM   #48
Default TED Calibration
I have an RF remote control wired up to the new MTU, so I can shut off & on to restart it.
But, I've been watching for a sync-up all day long and not seen one.
If it does occur, it might drift back into flip-flop mode by itself..
Calibration:
I figured out how to calibrate the new MTU/probes! I used the old TED setup as my standard.
(The old TED was calibrated using NStar electric meter).
I simply clipped the current probes from both units, on the same lines!
The watt readings should have been the same, but were not.
The Den TED was displaying much higher wattage..
So, I accessed the Technology menu of the new TED and adjusted
the offset so the power of both displays matched..
Ran the power up and down and saw perfect tracking between displays..
where2 (01-10-14)
Old 01-10-14, 08:21 PM   #49
where2
DIY Geek
What are you using for a line filter? I looked around my usual go-to electronics surplus place, but all their ferrite clams started their filtering in the 1Mhz range and went up from there.
It probably doesn't help my situation that I have a Square-D QO surge arrestor in the same panel I'm trying to measure. With my MTU feeding down a wire with only one device on the circuit (microwave), I get inconsistent communications at the readout. Doesn't matter whether the microwave is actually plugged in. If I follow your design and add an outlet or two right at the panel to plug my two MTU's into, I'd like to filter their feeds heading toward the panel.
Old 01-10-14, 11:22 PM   #50
The filter didn't work for me the first time I attempted to use it..
http://ecorenovator.org/forum/applia...ot-prints.html
XPF 20A Wired-In Noise Filter
XPF 20A Wired in Noise Filter x10 Pro | eBay
I think the filter is a pair, or maybe 3 pi network filters..
I'm not using the ground wire, since the caps sucked too much power.
Just using the series inductors. Large iron or ferrite rods wrapped with
medium gauge wire. 20A capable.
(Using the ground didn't increase the signal counts at all).
You could try making your own iron core inductor, just wind 2 or 3 feet
of wire around an iron or plain steel rod.
I made one a while back, with a 3/4" iron rod core. (for another experiment), it was easy.
Put the inductor in series with the Hot (black) wire going to the new outlet.
And make sure to attach the black wire from the MTU, on the outlet side of
the inductor.
It will block the signals from feeding back into the main breakerbox.
And keep noise and the capacitance of your surge arrestor off the signal path.
If you need a diagram, let me know.. I can draw one an snap a pic.. after I sleep...
