10-06-11, 08:06 PM | #21 |
$9.97 isn't too bad.. I'm planing on going to HD soon anyways (for mini-split install stuff),
and I just might pick up a couple of their $9.97 LEDs.. I still have one more of those Decorative bathroom LEDs to pick up too. |
10-07-11, 09:35 AM | #22 | |
10-13-11, 03:30 PM | #23 |
My lights that I ordered from China finally came in. They cost $5.85 each, free shipping.
Shipping time was twelve days. They were a bit smaller than I expected, but appear well made and they all do work. The smaller size can be a bonus, because I have some track lighting that will only take smaller bulbs. The bulbs are shown with a Utilitech Pro light that I got from Lowe's under some other brand name for $25. The Utilitech is larger, heavier and has four LEDS. It also has a diffusion pattern in front of the LEDs to spread the light out more. The smaller lights (no brand showing) use three LEDs. The light was advertised as warm white, and I would say that it does appear to be a pleasant comfortable color without the harsh blue cast I have encountered before. NEXT POST: Performance results. -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 10-13-11 at 03:32 PM.. |
10-13-11, 03:40 PM | #24 | |
my guess is the heat dissipation is going to be less than 8 watts. The heat sink will hold heat, and if you grab it and hang on, it will get very uncomfortable.. The glass enclosure (part that looks like a bulb) hardly warms up at all. |
10-13-11, 04:00 PM | #25 |
I've got some on the way, that I plan to gift to my daughter.
I'm still waiting for my order from China. But it's only been 11 days..
Dimmable GU10 6W 3x2W LED Spot Light Bulb Lamp Warm White 3200K 450Lumen | eBay Getting four, to replace the super hot halogen bulbs that don't seem all that safe, because the metal fixtures are surrounded by loose cellulose insulation in a lowered ceiling. Specifications: Base type :GU10(30°) Shell material :High strength glass Heat sink material :Aluminum, zinc metal alloy Input voltage :110V-230V Output power :6.0W Dimensions :80 x 50mm (Length & Diameter) Reflector efficiency:90% Light source :3x2W high power LED Body temperature :<60°C Color temperature :3000-3500K Source life :> 50,000 hours Safety assurance :CE & RoHS Lumen :430-450 LM Color : Warm White Dimming Range:10-100% Looking at that input voltage range, kinda makes me wonder about the power supply..?. 120vac LEDs bulbs in general.. What up with their power supplies? Will these things run off DC too? ~~~ Edit~~~ The mailperson just dropped them off. All four are very bright on 124vac. They will be installed this evening.. Last edited by Xringer; 10-18-11 at 12:32 PM.. Reason: Oct 18, China shippment here |
10-26-11, 01:59 PM | #26 |
Hey AC_Hacker,
Any problems with those A27 lamps from China? I'd like to replace 20, halogen Par20 50W in 4" recessed cans. I was considering the Ecosmart PAR20 from Home Depot (8w, 350 lumen, 40w equiv, 'bright white' 3000K), but they are $20 each. The lamps seem similar. Why does everyone think the ecosmart is $20, and the Chinese A27 is $6? Thanks - milanski |
10-26-11, 05:07 PM | #27 | |
No problems at all. The color looks very natural to my eyes. The dispersal pattern is rather narrow, compared to the 4-LED bulb in the pic, above. The 3-LED bulbs light intensity is definitely lower than the 4-LED bulb. $6 3-LED bulb = 700 lumens @ 36 inches (narrower pattern) $24 4-LED bulb = 1000 lumens @ 36 inches (wider pattern) Unfortunately, I can't find my Kill-a-Watt to give you a power comparison at this time. EDIT (11/10/2011): I found my Kill-a-Watt and the power reading from the $6 light is 6 watts, and the power reading from the $24 light is 11 watts. Considering that I paid the same for 4 of the 3-LED bulbs as I did for 1 of the 4-LED bulbs, I'd say the 3-LED bulbs are a great bargain. Having said that, each bulb has its place... I'd much rather read under the 4-LED bulb. The dispersion pattern on the 4-LED bulb really helps to spread out the light. There does not seem to be any claim that these bulbs are dimmable. -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 11-10-11 at 11:42 AM.. |
10-26-11, 05:45 PM | #28 |
Hmmm,
Strange that they advertise the 6w E27's as 'warm white' but with a temp of 6-8K. Maybe a typo on their part? You say the color looks natural, more like a 3k color? If so, I may pull the trigger and get a few. Yep, I assumed they were not dimmable. Still, wonder what would happen if I put them in my stove range hood, which has three light brightness settings. Thoughts anyone? THanks. - milanski |
10-27-11, 12:44 AM | #29 | |
So, why don't you just get a few, and see for your self? The shipping time was maybe 12 days... not so long really. It would be a real pain to ship 20 LED bulbs that you didn't like back to China... even if it was all about a failed attempt to try to save 283 bucks. Just try a couple of bulbs... if you really hate them, you could use them to illuminate your trash cans at night, for the rest of your life (they're supposed to last a really long time). -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 11-10-11 at 11:43 AM.. |
12-09-11, 03:10 AM | #30 | |
Heat recoverer
The operating principle of LED make them generate concentrated light.... Even LASER concentrated light if so desired. Consequently, for most lightning requirement, the LED generated light need to be diffused in order to be pleasing. This is a relatively easy function compare to "Concentrating" the light. Consequently, it is only normal that the LED will overtake the SPOT MARKET before any other market. |
