10-07-11, 04:04 PM | #21 |
We did it just over 2 years ago, I think the instructions tell you what humidity and so on it has to be for it to work well, I seem to remember that you don't want it to have rained within a week or so and of course all dampness should be gone, so you might need to borrow a 2nd dehumidifier to get your basement super dry, then of course you need to apply 2 coats and it's a heavy thick paint that has to be worked in a bit with a brush, but like I said, it should not be your only plan and even tho they claim that it will stop water my feeling is that if you truely have water coming in, not just humidity, that you have deeper problems.
The Following User Says Thank You to Ryland For This Useful Post: | Daox (10-07-11) |
10-08-11, 04:06 PM | #22 |
What is the best theoretical efficiency of a dehumidifier (in liters per kWh, for example)? This would give us a reference point.
EDIT: I found that condensing 1 kg of steam to 1 liter of water (@100°C) requires/releases 0.6267 kWh, so that would be 1.595 liters per kWh. That can't be right
Ecorenovation - the bottomless piggy bank that tries to tame the energy hog. Last edited by Piwoslaw; 10-08-11 at 04:14 PM.. |
