Old 10-23-14, 07:10 PM   #261
buffalobillpatrick
Whew! took hours, lots of stuff don't work in a ISR (Interrupt Service Routine)
delay(x) , lcd.print, &
biggest pain was
Compiler was optimizing out various "delay for loops" that I tried, even with index declaired volatile.
I wanted about 30 sec. delay between Compressor off & water pumps off.
analogRead didn't optimize out!
This WORKS!
Code:
//done in setup:   attachInterrupt(1, Stop_Compressor_ISR, RISING);// Attach Interrupt
    // (IRQ1 is on Digital Pin 3) Pin 3 going high (+) sets Interrupt 1
    // This is Master signal to STOP HP Compressor, by denergizing R3
    // with a short power cycle to Solar pump, which picks a relay
    // N/O point connects Arduino +5v to Digital Pin 3
    // Digital Pin 3 has a 10K pulldown resistor to Gnd.
    // This allows the water pumps to continue after Compressor is off
    // After a delay the master will power off this Slave Arduino
    //	This would be a normal ending sequence for HP satisfying Load
void Stop_Compressor_ISR()
//#define Max_Long_int_number   2147483647
#define Big_number               250000
  long Z;
  int Y;
  detachInterrupt(1);
  digitalWrite (HP_RLY_R3,                  HIGH); //Compressor OFF
  for (Z = 0; Z < Big_number; Z++) {analogRead(1);}  //delay about 30 sec.
  digitalWrite (HP_RLY_R2,                  HIGH); //Pumps OFF
  digitalWrite (ALIVE_RLY_R1,               HIGH); //Alive OFF
  do{Y = Y;} while (Y == Y);  //hang forever
Old 10-23-14, 07:21 PM   #262
buffalobillpatrick
Question:
If a water pump does stop working while HP is running, what is best sequence for shutting down?
Turn off Compressor & pumps together OR Compressor 1st & then delay before turning off pumps?
Old 10-23-14, 07:56 PM   #263
Oh no. What? Whoa...
This is why I am trying to stay away from interrupt and library calls. God save your soul.
buffalobillpatrick (10-24-14)
Old 10-23-14, 11:59 PM   #264
buffalobillpatrick
Hard to figure out when code looks correct & compiles, but just acts like No-ops.
From Nick Gammon, an Oz Arduino expert:
"The compiler optimizes, that is well-known. Variables shared between an ISR and "main" code should be declared volatile.
Attempts to make loops by doing something with non-volatile variables are frequently optimized away."
Old 10-24-14, 09:45 AM   #265
Originally Posted by buffalobillpatrick View Post
Question:
The reason to delay pump shutdown is to get the last few BTUs from each system heating cycle.
In my opinion, having a water pump fail is an emergency condition. Of course shut down the compressor first, then whether you allow the pumps to run on a bit longer or not is of little consequence, because your heating system will be going down until the failed pump is remedied or replaced.
Old 10-24-14, 09:48 AM   #266
biggest pain was...
Do you have any kind of physical simulator test fixture?
Old 10-24-14, 11:32 AM   #267
buffalobillpatrick
A/C Thanks, No on physical simulator test fixture.
In example, this compiles but don't work (no delay) even though Z & Y are not sharred outside this ISR
Code:
#define Big_number               500000
  long Z;
  long Y;
    for (Y = 0; Y < 10000; Y++) {Z = Z;}
Compiler must think "that don't make no kinda sense" why would anyone want to do this.
This however works (delays) volatile is key here, even though Z & Y are not sharred outside this ISR
Code:
volatile long Z;
volatile long Y;
Old 10-24-14, 11:49 AM   #268
Question:
Always try to run the evaporator side pump for a minute or two after the compressor stops. This way you will have eliminated any chance of the residual refrigerant freezing the hx as it peters out. A lot can happen in a few minutes.
The condenser hx is not as important. However, having the pump run as well will reduce the high side pressure and pinch off the residual flow faster.
Old 10-24-14, 12:06 PM   #269
buffalobillpatrick
Rewrite of estimate_COP to make it easier to understand & relate to Climatemaster graph
I would rather try to closely estimate COP, than to use trouble prone flow sensors.
Code:
  // COP estimation
  // http://www.climatemaster.com/downloads/RP881.pdf
  // p19 graph for model TMW036 W/W
float estimate_COP (void)
  int   cop;
  int   ESWT;
  int   ELWT;
  int   DELTA_T;
  float COP;
  ESWT       =  (Read_10K_NTC (SOURCE_IN_sensor));
  lcd.clear();
  lcd.home (); // go home
  lcd.print(F("ESWT="));
  lcd.print(ESWT);
  custom_delay();     //Delay 5 sec. & Checks Water SRC OUT
  ELWT       =  (Read_10K_NTC (LOAD_IN_sensor));
  lcd.clear();
  lcd.print(F("ELWT="));
  lcd.print(ELWT);
  if (ESWT > ELWT)  //if source is hotter than load
  cop = 80;    //force high COP
  else
  DELTA_T = ELWT - ESWT;
  lcd.clear();
  lcd.print(F("DELTA_T="));
  lcd.print(DELTA_T);
  if (ELWT <= 70)    //don't use constrain so graph lines on
                     //Climatemaster graph in Fig 2-11 p19
                     //can be interpolated past ends
                     //by map function, which only works on whole ints, not floats
  cop  =  map(DELTA_T, 10, 50, 73, 44);
  else if (ELWT <= 75)
  cop  =  map(DELTA_T, 15, 55, 69, 41);
  else if (ELWT <= 80)
  cop  =  map(DELTA_T, 20, 60, 65, 38);  //this maps the top blue line
                                             // on graph
  else if (ELWT <= 85)
  cop  =  map(DELTA_T, 25, 65, 61, 36);
  else if (ELWT <= 90)
  cop  =  map(DELTA_T, 30, 70, 57, 33);
  else if (ELWT <= 95)
  cop  =  map(DELTA_T, 35, 75, 53, 30);
  else if (ELWT <= 100)
  cop  =  map(DELTA_T, 40, 80, 49, 28);  //this maps the middle red line
                                             //on graph
  else if (ELWT <= 105)
  cop  =  map(DELTA_T, 45, 85, 46, 26);
  else if (ELWT <= 110)
  cop  =  map(DELTA_T, 50, 90, 43, 25);
  else if (ELWT <= 115)
  cop  =  map(DELTA_T, 55, 95, 40, 23);
  else if (ELWT <= 120)
  cop  =  map(DELTA_T, 60, 100, 37, 22);  //this maps the bottom green line
                                              //on graph
  else if (ELWT <= 125)
  cop  =  map(DELTA_T, 65, 105, 34, 21);
  else {STOP();}
  COP = cop / 10.0;
  return (COP);
Old 10-24-14, 12:37 PM   #270
buffalobillpatrick
I'm doing this "esoteric" master quick pulse of Solar tank pump to cause Int 1
because I'm out of pins on Master Arduino, and the AC power line for Solar pump will run between house & shop where this Slave Adruino will reside.
In any case I think that using Int 1 as a quick way to Shut Down of HP from
remote Master on "Normal HP satisfying Load" OR "Downshifting to boiler" is the best way.
