Old 08-15-14, 01:42 PM   #201
buffalobillpatrick
I don't mean to step on toes!
Only way I can understand someones code is to start messing with it.
My changes: some time names & blocking_delay >= on delays
Check my changes for being correct?
Ormston_Rev02
Code:
#include <Thermistor.h>
                                    //Got tired of counting zeros
#define  One_Sec              1000
#define  Half_Min            30000
#define  One_Min             60000
#define  Two_Min            120000
#define  Five_Min           300000
#define  Ten_Min            600000
#define  Thirty_Min        1800000
double evaporator, condensor;  //Variables for temperatures from thermistors
float HpLPM;                   //Flow rate from flow meter in L/m
float HpLPM1;                   //Flow rate from flow meter in L/m
int minLPM = 3;                //Minimum flowrate to run HP
int minEv = 2;                //Minimum evaporator temp
int maxCon = 65;              //Maximum condensor temp
byte runHP = false;
byte runCompressor = false;
byte runOutPump = false;       // pump to circulate water to house/tank
byte runInPump = false;        //fan in case of ASHP
const int demandPin = 4;       // input connected to external thermostat to request heat
byte demand = false;               // variable for reading if heat required from thermostat
unsigned long blocking_Time;          // Delay Time
unsigned long hpStart_Time;        // Time HP cycle started
unsigned long hpStop_Time;        // Time HP cycle stopped
volatile int NbTopsFan; //measuring the rising edges of the signal
volatile int NbTopsFan1; //measuring the rising edges of the signal
int hallsensor = 2; //The pin location of the sensor
int hallsensor1 = 3; //The pin location of the sensor
byte led = 13;
byte ledState = false;
byte comp = 5;
byte inPump = 6;
byte outPump = 7;
unsigned long prevMillis = 0;        //used for led blinking
Thermistor temp(0);
Thermistor temp1(1);
// ********************Temperature measurement starts here**************
void readTemps() { //read all temperatures from thermistors
  evaporator = temp.getTemp();
  condensor = temp1.getTemp();
// ********************Temperature measurement ends here**************
// ********************Flow meter reading starts here**************
void hpFlow () //This is the function that the interupt calls
  NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
void hpFlow1 () //This is the function that the interupt calls
  NbTopsFan1++;  //This function measures the rising and falling edge of the hall effect sensors signal
void readFlows()
  NbTopsFan = 0; //Set NbTops to 0 ready for calculations
  NbTopsFan1 = 0; //Set NbTops to 0 ready for calculations
  interrupts(); //Enables interrupts
  delay (One_Sec); //Wait 1 second
  noInterrupts(); //Disable interrupts
  HpLPM = (NbTopsFan / 2.75);
  HpLPM = (NbTopsFan1 / 2.75);
// ********************Flow meter reading ends here**************
void setup() {
  pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
  pinMode(hallsensor1, INPUT); //initializes digital pin 3 as an input
  attachInterrupt(0, hpFlow, RISING); //and the interrupt is attached (1 for Leonardo 0 for mega/uno)
  attachInterrupt(1, hpFlow1, RISING); //and the interrupt is attached (0 for Leonardo 1 for mega/uno)
  pinMode(led, OUTPUT);
  pinMode(comp, OUTPUT);
  pinMode(inPump, OUTPUT);
  pinMode(outPump, OUTPUT);
  pinMode(demandPin, INPUT);
  blocking_Time = millis();
void loop() {
  readTemps();
  readFlows();
  demand = digitalRead(demandPin);
  unsigned long current_Time = millis();
  if ((demand == true) && (blocking_Time >= (current_Time - Two_Min)))
  //Wait 2 min.
  if (runHP == false) hpStart_Time = current_Time;
  runHP = true;
  else
  if (runHP == true) hpStop_Time = current_Time;
  runHP = false;
  //*****HP startup cycle********
  if (runHP == true) runInPump = true;
  if ((runHP == true)
     && (hpStart_Time >= (current_Time - Half_Min)  //Delay compressor start 30s
     && (HpLPM > minLPM)))                          //after starting in pump
  runCompressor = true;
  if ((runHP == true)
     && (hpStart_Time >= (current_Time - One_Min)))
  runOutPump = true;           //Delay out pump start 60s after starting in pump
  ledState = true;             ///turn on pin 13 led after startup of HP
  //*****HP shutdown cycle********
  if (runHP == false) runCompressor = false;
  if ((runHP == false)
     && (hpStop_Time >= (current_Time - Two_Min)))
  runInPump = false;
     && (hpStop_Time >= (current_Time - Five_Min)))   //delay 5 min.
  runOutPump = false;
  blocking_Time = current_Time;
  ledState = false;               //turn off pin 13 led after shutdown of HP
  //***Check flow rates above min***
  if (HpLPM < minLPM || HpLPM1 < minLPM)
  blocking_Time = (current_Time + Ten_Min); //prevent cycle restart for 10m
  runHP = false;
 //***Check evaporator/condensor above/below limits***
 //   not intended for defrost purposes, halts system for 30m
  if (evaporator < minEv || condensor > maxCon)
  blocking_Time = (current_Time + Thirty_Min); //prevent cycle restart for 30m
  runHP = false;
  digitalWrite(led, ledState);
  digitalWrite(comp, runCompressor);
  digitalWrite(inPump, runInPump);
  digitalWrite(outPump, runOutPump);
Old 08-15-14, 02:15 PM   #202
buffalobillpatrick
Added: Read_10K_NTC_C
guessed at A0 & A1 for evap & cond input pins, change as required
Ormston_Rev03
Code:
#define evap_Sensor           A0   //???
#define cond_Sensor           A1
int evap_Temp, cond_Temp;  //Variables for temperatures from thermistors
byte runHP = false;
byte led = 13;
byte comp = 5;
byte inPump = 6;
byte outPump = 7;
void readTemps()
{ //read all temperatures from thermistors in C
  evap_Temp   =  (Read_10K_NTC_C (evap_Sensor));
  cond_Temp   =  (Read_10K_NTC_C (cond_Sensor));
void readFlows()
int Read_10K_NTC_C (int which_sensor)
  #define sample_cnt 30
  float alpha =   0.9;     // factor to tune
  float average = 0.0;
  float steinhart;
  int I;
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// TEMP. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3892
// the value of the series resistor
#define SERIESRESISTOR 10000
  for (I=0; I< sample_cnt; I++)
  average =  alpha * analogRead(which_sensor) + (1-alpha) * average;
  delay(10);
  // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert to C
//  return (round(steinhart * 1.8) + 32);       // round to whole number
                                              // & convert to F
return (round(steinhart));         // round to whole number, return int
}  // end of Read_10K_NTC
void setup() {
  pinMode(evap_Sensor, INPUT); //init
  pinMode(cond_Sensor, INPUT); //init
void loop() {
  readTemps();
  readFlows();
  //Wait 2 min.
  runHP = true;
  else
  runHP = false;
  if ((runHP == true)
  if ((runHP == true)
  runInPump = false;
  runOutPump = false;
  runHP = false;
  if (evap_Temp < minEv || cond_Temp > maxCon)
  runHP = false;
Old 08-15-14, 04:50 PM   #203
Ormston_Rev03
PPB,
Just loaded & compiled Ormston_Rev03.
Compiles just fine.
I still don't have Thermistors hooked up, or anything else but power.
I'm not seeing any signs of life... maybe that's a good thing.
buffalobillpatrick (08-16-14)
Old 08-15-14, 05:08 PM   #204
I think I spoke too soon...
I didn't watch long enough.
After reset, I see a quiescent period of 2 minutes, which is good.
Then I see SSR 3 come on continuously
I also see SSR 2 come on at regular intervals of about 1 second on, 3 seconds off.
As I write, I'm now seeing both SSRs come on at regular intervals of about 1 second on, 3 seconds off.
There may have been other pattern, but I was busy typing...
Ormston,
What kind of connections do you have for your flow meters??
I went by some of our larger supply houses, and couldn't find anything.
Old 08-15-14, 07:01 PM   #205
Ormston
Ormston,
This is my setup, 3/4" version and I'm sure it's 3/4 BSP.
Parallel thread but seems to seal with plenty of PTFE tape.
My flow sensor is now completely dead, was installed last Oct/Nov so not very reliable.
Old 08-15-14, 07:39 PM   #206
What are the brass connectors that attach directly to the sensor called?
Old 08-15-14, 09:57 PM   #207
ICanHas
Banned
I would set it up like this with an o-ring just as it is intended. This being the pump's male end and the green being the o-ring. PTFE is not harmful, but NEVER use pipe dope on plastic parts. It can weaken and fracture the parts down the road.
The o-ring also acts as a spring to keep the thread under tension so it doesn't vibrate loose.
Go to a small hardware store and hand-fit an o-ring from their selection. Home Depot/Lowe's would not have o-rings by the piece like this.
The Following User Says Thank You to ICanHas For This Useful Post:
Old 08-16-14, 02:44 PM   #208
The flow sensor issue is really slowing me down.
The thread is BSP as you said, which is extraordinarily hard to find in the US. I've come to the conclusion that the fitting, and the way it seals, with the two smoothly machined faces separated by a gasket, is really a good system, but it doesn't seem to be employed in the US.
Mikesolar made some very relevant posts HERE, and HERE, that have given me sufficient information to find out just how difficult it is to get these parts, here in the land of the free, home of the brave, blah, blah, blah.
On your joint, I think that you could have eliminated part "C", and just connected "B" directly to your sensor with a proper gasket to seal between the parallel flat faces of your sensor and what ever it was that allowed pipe "A" to be tightened down with nut "B".
But anyway if the failure rate you are experiencing is typical, it really makes me wonder...
I did find an ultrasonic flowsensor HERE that does look very interesting, no moving parts, it also looks like minimum flow restriction, but the cost might be brutal.
More later...
Name:	Ormston Sensor joint.jpg
Old 08-16-14, 02:58 PM   #209
BBP,
I loaded your monster code (combined all 5 parts) into the Arduino simulator, and after I gave it "LCD.h", it just started chugging away with no errors that I could see.
Probably no surprise to you...
Old 08-16-14, 03:06 PM   #210
Ormston
More later...
AC
A is 22mm copper pipe (metric equivalent or 3/4 though not sure how close in size they are), it sits inside B/C with an olive as a seal(compression fitting).
Known as a 3/4 female iron.
BSP - F/I - Female Iron - Straight Compression Fitting | eBay
The Following 2 Users Say Thank You to Ormston For This Useful Post:
AC_Hacker (08-16-14), buffalobillpatrick (08-16-14)
