Old 12-19-17, 11:44 AM   #11
svensi
Maybe this will help others if they have the same issue.
It did! Thank you very much!!!!
Hämta en
från
och spela på
eller direkt på
om du vill ha den bästa upplevelsen.
svensi is offline   Reply With Quote
Old 03-14-18, 11:58 AM   #12
Quick update. It is a little over a year and the repaired garage opener has been working fine. The cheap repair was more that worth it.
