09-08-15, 10:59 AM | #11 |
LED head light with high beam on.
09-27-15, 02:02 AM | #12 |
Building my own furniture.
Some of the corners are still hot from welding. Need a new entertainment stand. Cheap particle board junk from walmart is between $100 to $200 and falls apart after a few years. My current one sucks, bought it used off CL 2 years ago. It sags and not all the cabinets close and I fear its going to collapse any time I move it to clean and dust behind it. The nice metal and wood entertainment stands like I want to build start at $900 if I wanted to just buy one. Between the steel, wood, casters, paint I will have well under $300 in it. |
The Following User Says Thank You to oil pan 4 For This Useful Post: | jeff5may (11-07-15) |
09-28-15, 12:50 AM | #13 |
My small halogen work lights after being on for an hour or 2.
I believe they are 100 watt. Whatever the lowest common wattage for a given halogen tube size is what I typically run. |
09-30-15, 02:45 AM | #14 |
32 inch red neck LED light bar.
10-10-15, 12:44 AM | #15 |
Gas range.
10-10-15, 01:04 AM | #16 |
In other news I tried out a FLIR E6.
I don't care for it. It appears to take a "bleached out" regular image and over lays it with a thermal image. The image looks lower resolution then a flir i7 but the flir ligature claims its the same resolution. I would say save your self $600 to $1,000 and just buy the "inferior" i7. |
11-07-15, 12:28 PM | #17 |
Wall heater with pilot light and while running.
01-28-16, 12:03 PM | #18 |
72kw gas turbine compressor, turbine side.
The flir is aimed at the combustion chamber cap. |
01-28-16, 12:37 PM | #19 |
Nice picture.
01-31-16, 12:57 PM | #20 |
What kind of generator is that. At 72kw it's a really small gas turbine. Most I'm familiar with start around 4mw. IE lm1500 LM2500 running a power turbine and a generator. 72kw would be more like a generator cart/ start cart.
Makes me want an ir camera even more. Before we move and start looking at houses in will have one to check over the houses we look at. |
Tags |
diesel engine, efficiency, flir, insulation, lawn mower |
