05-01-15, 09:15 AM | #11 |
This manual describes the Envoy setup.
http://enphase.com/global/files/Envo...eration_NA.pdf It talks to the microinverters through the neutral wire. You don’t want it plugged into a power strip. Plug it close to where the solar breakers come in. Mine is plugged into the subpanel where the solar comes in. Did the power company put your new meter in? Very cool you are up and running! |
05-02-15, 04:49 AM | #12 |
cost
245 watt sharp panels were $185 scored from craigslist. My m215 inverters were ebayed between $125-140 shipped. I bought one m250 for $155 shipped. 2 sets of trunk lines for $25 a connector, I bought 9x, 3 extra for future expansion totaling $225. Racking was unistrut, 4x 10' pieces for $23 ea, and 24x angle brackets for feet $4 ea. Screws and misc hardware $30. 2 tube black jack roofing sealant $3 each. 12-4 outdoor romex,250' for $180, I used about 60' but this was near the lowes price for 60' of cut wire. New breaker panel $70 plus a few breakers $25. Part of my update to a roomier panel I changed all my double poles to thicks, I think it looks better and its easier others to identify the big breakers. I paid $300 for the enphase envoy which should monitor my panels, not required but should be helpful once I get it set up.
Totaling very close to $2950 for 1.4 kw. $2.10 per watt. With the current set up I could easily plug in 3 more for just cost of panels, inverters and racking, about $1050. Bringing cost down to 2.1kw for $1.90 per watt. Last edited by gtojohn; 05-02-15 at 09:52 AM.. Reason: bad math |
05-02-15, 05:10 AM | #13 |
Pinball, I don't have a revenue meter yet. Electrical needs to be tidied up before final. Until then system is being tested and run with current smart meter. Since the grid tie won't island or feed back without grid power so safety isn't an issue. As you probably know the enphase require grid power for 5 minutes before the will produce power. With my base usage and small array, power going back won't be much of a revenue lost either. My main goal is to trim off the most expensive part of my electrical usage assuming my payback would be fastest.
05-04-15, 09:31 AM | #14 | |
05-04-15, 09:47 AM | #15 | |
The guy said when they would catch them was when they forgot to flip it back over and they would get negative usage. |
05-07-15, 07:20 AM | #16 |
Oklahoma is backwards on winter electric rates. We have a 2 tier system where the 1st 600KWH per month is billed @ 9 cents, then the rate drops to 5 cents for all use over 600KWH. In summer we have TOU rates where you pay 6 cents off peak and 20 cents on peak (2-7pm M-F). Fortunately the 2-7pm peak rates are well aligned with solar peak output. Summer is June 1 - Sept 30, winter is the other 8 months.
05-07-15, 12:26 PM | #17 |
You may already know, but hooking up any backfeeding/producing system to any utility requires their permission so use sound judgement (ie is anyone gonna give a crap and how much crap could fly, etc). Often the utility and local code requirement will really eat into the costs so its helpful to map that out and have approvals first.
And as noted almost all meters continue to add when spinning backward, some including the digital will trip alarms as well. I did a minor system to cover phantom load, as in my area the utility doesn't offer net metering and charges crazy fees/rates for solar hookups. Also no state or utility rebates. I used one enphase and a couple large unisolar thin film panels, and it never produces more than my homes typical phantom load. More of a fun test as my local power cost is dirt cheap so it'll break even maybe in a decade or so if at all. Also look into the requirements on the tax incentives and rebates; some require certifications, etc. Depending on your rates, a lot of your payback may be tied up into this so it's important. Other things like how your insurance will handle panel damage or roof damage where the panels are is worth looking into. Your racks look nice! |
06-21-15, 04:34 PM | #18 |
I just finished my first whole month billing cycle with my small array. 638 kwh of usage total, in June I used less power than January and thats with gas heating. Which is actually tied for my 3rd lowest usage in the last 24 months. During this current bill cycle we used plenty of a/c, ceiling fans and ran the pool pump as needed. Both a/c had separate failures which led to extended periods of run time before I became aware we were without a/c. My usage was a little higher because of this. My monitor shows that despite unusually cloudy weather I've generated 210kwh this month which retails close to $30.
The Following 2 Users Say Thank You to gtojohn For This Useful Post: |
06-21-15, 11:56 PM | #19 | |
I couldn't imagine 15cent electricity; I'm at 3.8cents + 2.5cents distribution Congrats! |
06-22-15, 10:48 AM | #20 |
Congrats gtojohn! I wish I had a nice little array that size.
