Old 03-01-14, 03:37 AM   #11
WyrTwister
I'm pretty sure PAG is only used for low voltage compressors. It has a low breakdown voltage. And it's even more hygroscopic than POE, hence it's becoming less commonly used.
A few years ago , we had a 2002 Buick Century . I replaced the GM V-5 compressor , accumulator and orifice . I was told to use PAG oil . Can not remember which viscosity .
When it gets warmer & will either have to replace the V-5 on a 1996 Chevy Lumina 4 door sedan , or replace the O-rings and seals on it . Will have to look it up , but I suspect it came from GM with PAG oil ?
God bless
Wyr
Old 03-01-14, 08:55 AM   #12
That's an old design. Nowadays, a lot of automotive HVAC compressors are using POE, except Hyundai/Kia that use PVE.
WyrTwister (03-01-14)
Old 03-01-14, 10:23 AM   #13
WyrTwister
Good to know . However , I see no plans for a Hyundai/Kia in my future ?
Thanks , :-)
Wyr
God bless
Old 03-01-14, 02:29 PM   #14
GM switched to PAG 150 oil and R134a in like 93 or 94. Later (this century), they switched to thin PAG oil, like 40 wt or so.
Old 03-04-14, 07:41 AM   #15
WyrTwister
You are probably correct . Our 1991 Caprice is R-12 . Or , it was , that is the car I am interested in converting .
The 1996 Lumina is R-134a .
God bless
Wyr
