06-10-10, 08:50 AM | #11 |
Remotes, More is better!
I found one of these on sale at Ace..
Remote Switch by Thomas & Betts - More Electrical dimmers and switches at doitbest.com I know it has a little parasitic load, but I use it to take my whole home entertainment system (and Moto cablebox) off-grid (nightly). That's got to be saving a bunch of watthours and keeps the den cooler in the summer.. |
06-11-10, 09:46 AM | #12 |
I just tested my furnace, it was drawing 24 watts!
I wonder about adding a thermostat or something to the power going in, so it would cut power if the out door temp was above say, 50F out. As it is I flipped the breaker off. |
06-11-10, 10:37 AM | #13 |
How did you test your furnace? Clamp meter?
06-11-10, 12:24 PM | #14 |
With hardwired stuff, the only sure way that I know of, is use the grid meter.
http://ecorenovator.org/forum/conser...-yourself.html Just turn off every breaker in the panel, Except for the one you want to measure.. It will take a while, but the results are pretty accurate. (As in, they will coincide exactly with your bill). |
06-12-10, 08:44 AM | #15 |
My furnace has a screw in fuse next to the switch that turns it off so I pulled that fuse and used my Fluke Multi Meter, set to amps, sticking the probes in the light bulb like fuse socket.
I was going to barrow a clamp type amp meter but I had my Fluke meter at home and it's accurate. |
06-12-10, 09:22 AM | #16 | |
turn it off and use a VOM to measure amps across the switch terminal screws! At these low power ranges, I'll bet the VOM method is a LOT more accurate than a Kill-a-Watt.. (At least my Kill-a-Watt).. |
06-13-10, 12:16 PM | #17 |
My kill-a-watt is pretty accurate down to about a watt, under a watt and it flickers from 0-1, I used my Fluke meter a while back to test my cell phone charger because my kill-a-watt was showing -0-, the fluke agreed.
06-14-10, 12:38 AM | #18 |
Nice thing about a VOM is the ability to read the miliwatts.
I get the feeling that my Kill-a-Watt would have a hard time seeing a 400 mw load.. Of course, I loaned mine out to a buddy and it got abused.. |
