08-29-12, 08:53 PM | #151 |
Thats quite the rig marke!
FYI, you can post multiple pictures in one post.
08-29-12, 09:10 PM | #152 |
marke's drilling rig...
Hey, great pics!
It looks like you went with a hydrolic motor and chain drive, which worked well for Vlad, too. Great going. Keep us posted as to how your progress goes... winter conditions aren't so very far away. Best, -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 08-29-12 at 09:13 PM.. |
08-30-12, 02:45 PM | #153 |
the hole i drilled to day. it took me 3 weeks to build the rig and to dig 4 holes to 80ft. the temp was 90 to 100 here so did not work to fast. to day on the last hole temp was 70s so went good.
08-30-12, 02:48 PM | #154 |
new bit 6in
08-30-12, 02:49 PM | #155 |
pull chain to remove pipe
08-30-12, 02:51 PM | #156 |
4500lb to remove pipe 80ft
08-30-12, 02:52 PM | #157 |
top of rig with pull cable
08-30-12, 02:53 PM | #158 |
pipe installed
08-30-12, 02:55 PM | #159 |
all 3 holes
08-30-12, 07:05 PM | #160 |
I wish I was that fast. So what did you use to fill the hole with? Did you use a tremmie pipe to fill your grout, or did you just fill from the top?
