Old 11-23-09, 06:52 PM   #141
Just got back from my first test drive. I had nothing hooked up except the contactor. Not that having the ammeter would help as it is pitch black out atm. I would have been able to see the voltmeter though.
Old 12-01-09, 12:40 PM   #142
This past weekend I took the time to piece the mower together enough to actually do some work. I was able to get the lawn mowed with two charges, but I still have some hangups with it.
The pulleys are still sized wrong. 1st gear is way too slow to mow, and 2nd is very fast. I spent most of my time mowing in 1st gear. However, the majority of the power to mow goes into keeping the blades spinning, so I'm loosing tons of power by not being able to mow faster. Resizing the pulleys will allow me to slow the mower down in 2nd gear to a reasonable speed and also slow down the blades so they aren't sucking soooo much power.
The drive belt is slipping. I did try mowing in 2nd gear for a while. It worked okay despite flying around the yard. However, when I hit a bit of an incline, the mower would really slow down. So, I need a smaller belt or I need to adjust the clutch. Moving around this time, the mower was pulling 50A vs the 25A it had been using previously in my testing.
The temperature was pretty low. On Friday, I think it was roughly 40 degrees when I was mowing. This really kills the power output of batteries. I believe most electric cars loose about half their range in the winter.
The batteries have not been used yet. On Saturday, my second time using the mower, I was able to go quite a bit farther on one charge. I think this was a combination of exercising the batteries the day before and also warmer weather (55 degrees).
So, totaling this all up, the mower was consistently pulling 110A the entire time I was mowing. Unfortunately, I didn't think of timing it to see how long the battery actually lasted. In summer and with the pulleys sized correctly, I think it will be pulling ~70A.
But, that is the last time I'll be mowing for this year. Time to put the snow blower on!
Old 05-03-10, 06:15 AM   #143
I had the mower out for the first time this year. Mowed half the yard (on two charges). The batteries lasted a LOT longer on the 2nd charge, so they definitely need to be woken up (they don't last as long after sitting for long periods and need to be 'exercised'). Mowed great, still need the pulley's resized though for more run time and reasonable speeds. I also noticed my drive belt is slipping so I'll need to adjust that as well. In addition to that, I need to get some permanent wiring in there. I'm still using alligator clips to power the contactor and on/off switch as well as the voltmeter.
I gotta say, I love the mower. After basically wheeling the mower out of the garage, and giving the batteries a quick top off charge I was mowing without any problems. After mowing I got out my gas powered weed wacker... just pull after pull and even after it was running it wasn't running good. What a pain. I'll be replacing that soon with a Ryobi 18V lithium ion trimmer that HomeDepot is selling. I'll write up a review once I've used it a bit.
Old 05-03-10, 09:49 AM   #144
MetroMPG
Infrequent noob
The ecorider lives!!!
How many minutes run time would you say you got per charge?
And how did you decide when to quit and recharge?
Old 05-03-10, 09:55 AM   #145
Dang, I knew I forgot something haha. I didn't time how long I could run.
To decide when to stop, I just have a voltmeter monitoring total pack voltage. When I hit 33V, I stop. This is a bit low, but thats what I'm currently using.
Old 05-03-10, 09:59 AM   #146
MetroMPG
Infrequent noob
Run time would be good nerdly info to know.
So you still have half the lawn left to do? Going to mow some more tonight?
Old 05-03-10, 04:52 PM   #147
Christ
Re: Trimmer
Ryobi usually makes some pretty good tools. They're a sister (brother?) company to Black and Decker, as well as Ryan, and a couple smaller companies.
I had some tools from the Ryobi +ONE kit, they were a dream to work with on sites where power was a commodity (no waiting for a hookup, etc.), but the batteries didn't seem to stand up to the length of use I needed from them. As such, I employed 2 chargers and 2 spare batteries.
The lithium kits have longer run time, and more power-per-minute discharge capacity when necessary. They're supposed to be a better battery for the tools than the +ONE kit's batteries, because they can stand up to longer discharge cycles (continuous duty) and use.
I look forward to your review!
Old 05-03-10, 06:52 PM   #148
Yeah, I still have my field left to mow. I'll do it sometime this week. I'll get the runtime then.
Old 05-05-10, 05:56 AM   #149
I mowed my field last night. Got it all done in one charge. It seems I have roughly 25 minutes of use until my pack voltage gets down to 33V. Not too shabby. I'm hoping that the pulley changes will increase that to about 30 minutes.
Old 05-05-10, 08:02 AM   #150
One other thing I noticed while cutting this weekend was that my motor is running hot. Not real happy about that, but its not crazy hot, so I should be able to deal with it with some sort of fan. I'm currently thinking about putting a radial fan on the tail shaft and make some ducting that goes over the motor.
conversion, electric, lawn mower, tractor
