Old 04-18-11, 05:43 PM   #101
Originally Posted by solar1 View Post
Have a look at this link psl-heat transfer systems and this photo explains it .
This looks like a heat recovery ventilator. They're used over here mostly in newer houses that are sealed better and need fresh air. They're a great idea, but this isn't what I'm doing with this project.
Old 04-18-11, 05:51 PM   #102
how do you insert photos in this ??
If you are trying to use photos that are already on the Internet,
  • locate the URL of the photo
  • copy it to clipboard
  • use the 'insert photo' button
  • paste the photo URL to the dialog box
If you wish to include images that are NOT on the Internet,
  • Go to the 'Manage Attachment' button... it will open a new page
  • Press the 'Choose' button
  • upload
  • the URL of your photo will be there (right click) in 'current attachments'
  • follow steps given at the top of this page
I like to center my photos, I think they look better, so I highlight the picture code and use the 'center' button...
ID:	1418   Click image for larger version
ID:	1419   Click image for larger version
pachai (05-07-11)
Old 04-19-11, 12:57 AM   #103
Here is the ventilation heat exchanger thread:
DIY ventilation heat exchanger
If you already have one, or are planning to get one, please share any info that might be useful.
Daox, have you noticed that this thread is already pinged by heat-booster.com?
Old 04-21-11, 05:45 PM   #104
I came home today to see the attic fan blowing. I'm still working on a data logging setup for it to see what is actually happening.
Old 04-25-11, 06:37 AM   #105
MetroMPG
Infrequent noob
Get some / recycle some attic heat this weekend?
Old 04-25-11, 08:06 AM   #106
You betcha. I was gone this weekend, but now that its fully automated, it kicked in and heated the house at least on Sunday. When I came home it was still on.
Old 05-09-11, 10:28 AM   #107
tweeker
Green Energy Pioneer
Default Uploaded Pictures Test for Air Conditioner HP
I might have figured it out? We will see ?
tweeker is offline   Reply With Quote
Old 05-09-11, 02:12 PM   #108
Since tweeker bumped my post up I thought I'd give an update. The system and been working very well and I'm quite happy with it. Pretty much any sunny day (minus one day that was 20 mph winds) itll turn on and heat up the kitchen from the mid 60s to 69-70F.
I haven't toyed with the datalogging yet either. Its working, I'm happy. I'm okay with that for now.
Old 05-23-11, 09:03 AM   #109
Well, I had a bit of a hiccup with the system over the weekend. I actually wasn't even home, but came home Sunday night and the blower was blowing. However, I also saw that the damper in the kitchen wasn't pusheed up as high as it normally is. So, I went to check things out and sure enough, one of the fans wasn't turning. I'll have to pull it out and see whats going on.
Old 05-24-11, 09:52 AM   #110
Weed Dog
Question The Chimney as Plenum
Is the chimney sound, i.e., a sealed plenum? That visible portion appears so, perhaps you even tuckpointed recently? I live nearby, in Milwaukee, and my chimney was built of cream city brick, once a popular local building material. I've had to replace bricks and mortar that cracked, fell out of and into the chimney, and also disintegrated into sand, due to the ravages of time, stack temps and combustion products from my oil burner. Perhaps even poor manufacturing and improper firing of the brick occurred.
Cream city brick, I've read, tends toward greater porosity than some other types, and positive pressure in the chimney may encourage exfiltration of particles. I've found small quantities of sand around the base of my chimney in the basement, and that suggests to me that some soot, a nasty eye and respiratory irritant, may also have been pushed into the basement atmosphere.
Had you considered lining the chimney with rectangular or round ductwork? Some lurking experts might comment about whether this would increase laminar airflow, reduce turbulence and surface effects from the brick, and perhaps cut down the time that the blowers need to run, thereby reducing electricity consumption. Perhaps the effort would not yield substantial efficiency benefits...?
Weed Dog is offline   Reply With Quote
attic, heat, reclamation
