#1031 | |||||
![]() Quote:
BTW, seek out the forums where people have built refrigeration devices to chill computer CPUs... Gobs of great hardcore DIY info there. I think you are standing at the door to insanity, we're here to help pull you through. -AC_Hacker
#1032 |
![]() launboy, you most likely know someone who knows someone else. Just ask around.
TomS |
#1033 | ||
![]() I just remembered there's a guy who live a fe houses down from me that doe HVAC for a living. I know he'd have the tools and knowledge. Never really talked to him though. This could be a valuable resource in my projects, especially if he happens to find what I'm doing interesting.
"I think series would be better if I did this..." I wrote that wrong, I was thinking parallel would actually be better, but maybe I'm wrong. What do you all think, and what's the reasoning behind it? Quote:
I think so! Although the Dehu frost sensor probably goes by temp and the air temps ill be running in may be below its frost threshold(around 32* I'd guess). Quote:
Adam |
#1034 |
Uber EcoRenovator
![]() Launboy what a great hack. A perfect use for an old unit. The cost of heating a hot tub ouch. If I may suggest, what about installing a length of stainless tube in the return line for the circ. pump for the hot tub. I would think a piece of 0.375 to 0.5 inch dia about 4 to 6 feet of tube would work well for the condensor side. Don.t forget the counter flow very inportant. To just drop a fined evaporator into the water would be combersome. Take your time, line up some borrowed tools and hack with a little finness.
The shop GSHP is indeed providing all it can for heat. The heat exchangers are picking up all the heat produced by the compressor. In fact they are likely oversized by alot. I have mixed feelings about installing the larger compressor. I have some room for more insulation in the roof. But best of all I have some very good results with solar hot water. The rear of the shop has about 300 sq ft. for solar hot water panels. During a sunny day a huge amount of heat is avalible and its FREE FOREVER. Have a look at the other post about solar heating. There is a photo there of my friends helping to install the last panel on my home. You may want to consider a panel for your hot tub. The heat is free for the collecting. Randen Happy Holidays Everyone |
#1035 |
![]() Randen, any reason for using stainless instead of copper for the condensor HX? Putting the coil in the tub directly is definitely a very ugly way of doing it, but for my initial proof of concept to see if I can pull enough heat from the atmosphere in this cold air to make moving forward worth it, it'll work. I'm putting it in front of the main suction grate as it's a place no one sits in front of and it'll help pull water through.
I actually do have solar water heat, 120 sq ft on my south facing garage roof. ![]() They heat our pool and hottub in the summer with no problem. I've gotten the hottub over 120*F in the summer on accident once or twice. They're rated at 120,000 BTU but I think they rarely achieve that full output. Unfortunately being unglazed the efficiency drops wayyy off with any wind or low outside temp. I did consider using it to create low grade heat for the HP instead of the air when the water temp is warmer then the air. That adds complexity though. Maybe next this summer when I can make a Ref. - Water HX. The solar has appeal in your application too! You said it works really well when it's sunny and provides hot enough water on its own, but on the days where the water isn't hot enough to use directly you could run it through the heatpump. Adam |
#1036 |
Uber EcoRenovator
![]() Launboy Good job with the solar. Did you know there are polycarbinate sheets for roofing avalible to cover your solar hot water collectors. The home Depot and other suppliers carry them. They are clear corrigated roofing sheets treated for ultra violet exposiure and quiet reasonably priced. Just to cover them to prevent the wind and exposure from removing heat would improve their efficency.
Launboy wrote The solar has appeal in your application too! You said it works really well when it's sunny and provides hot enough water on its own, but on the days where the water isn't hot enough to use directly you could run it through the heatpump. The short answer yes but no. Don.t forget if there is no heat the heat pump is not going to help. You will only gather the small amount of heat that is there and start to freeze the panel. Remember the solar hot water panel is insulated all around and if there is no sun there is no heat and you will form frost on the interior of the panel. On the days with no sun the Geothermal heat pump starts and warms the concrete floor from the huge source 6ft down in the ground. When its 20 deg F outside the ground temp is 50 deg F a great source of heat. Randen |
#1037 | ||
![]() Quote:
Adam |
#1038 |
![]() Ordered the R22a (R290) today and will be replacing the R22 refrigerant when it gets here. How would I go about checking the known benefits of the conversion, before and after? Take temperature readings at the vents? Its a 220v unit, figuring a kill-a-watt meter won't hook up to it. How about taking a meter reading with all of the power off but the ASHP? Any ideas?
The ASHP is an outdoor unit by the way, with the ducts (conditioned return and heated/cooled air) go into the side of the bulding. If a leak so happened to occur, it would be outside. |
#1039 |
![]() Did I read somewhere that there is also someone making gauges that have the R290 refrigerant on them? In Australia?
#1040 | |
![]() Quote:
The ones I see there right now are pretty expensive. A R22 set will be good for reading the pressures, but the pressures of R290 will be lower than for R22. To do super heat and sub cool optimization, you will need a R290 PT chart, there's one on the manifesto thread, search for it. I put a super heat and sub cool explanation in the thread too. You might search the Internet for other explanations of the procedure. Sometimes reading how to do it from several sources makes it easier to understand. -AC_Hacker
The Following User Says Thank You to AC_Hacker For This Useful Post: | Roostre (01-25-18) |
Tags |
