02-23-14, 08:30 AM | #91 | |
You said you had a leak ? The drain ? God bless Wyr |
02-23-14, 09:13 AM | #92 |
Yep. I had forgot to cut the hose . Turned on the ac. hour or so later i heard water drip sounds went outside hose had a kink not lettin out the water so it backed up. I cut it shorter so it couldnt get a kink. Been workin perfect since.
02-23-14, 09:52 AM | #93 |
condensate hose
When I installed Sanyo #1, I was worried about the drip hose.
The Hole-in-the-wall was a tight fit, so I didn't know if there might be a kink in the condensate hose.. So, I tried blowing air into the end of the hose.. (Yes, with my very own lungs). The air flow seemed VERY slow.. So, I had to do a run-test on the first hot spring day.. No water dripped down the wall.. And, water was flowing out the end of the hose! No Kink!!
The Following User Says Thank You to Xringer For This Useful Post: | buffalobillpatrick (05-27-14) |
02-23-14, 10:34 AM | #94 | |
02-23-14, 10:40 AM | #95 | |
02-23-14, 10:42 AM | #96 |
1050 square ft.
05-27-14, 11:10 AM | #97 | |
What size breaker would be correct ?? I could also add a Time delay Fuse of 15A ?? |
05-27-14, 01:58 PM | #98 |
Use a 20A breaker and a current sensor.
The Following User Says Thank You to NiHaoMike For This Useful Post: | buffalobillpatrick (05-27-14) |
05-27-14, 05:26 PM | #99 | |
At the very least 13.4 amps * 1.25 = 16.75 amps -> # 12 wire and 20 amp time delay fuse . If you need to add in condenser fam figure it the same and add the product to the 16.75 amps . The 125% is for continuous duty . God bless Wyr |
The Following User Says Thank You to WyrTwister For This Useful Post: | buffalobillpatrick (05-27-14) |
03-25-16, 12:02 PM | #100 | |
We try to use the Maximum Over-current info to size the wire and the fuses / circuit breaker . To avoid nuisance tripping & call backs . For all HVAC equipment . You also do not have to worry about LRA or the phase of the moon . God bless Wyr |
