10-13-10, 01:50 AM | #1 |
Hello from Budapest, Hungary
Hello,
My name is Peter and I am from Budapest, Hungary. I found this site when I searched for a DIY recuperator plan. I plan to build a house next year. First I wanted a passive house, but my calculation ended up by a 48 year payback period, so I decided to bulid a standard house, with very good insulation and a recuperator. I am an electrical engineer, I do a lot of mechanical work as well as a hobby, for example remote controlled airplanes. That is why I believe I could make a DIY recuperator. I found a lot of good information on this site, thank you for that. I will post my own experiences when I have some. Regards, Peter |
10-13-10, 06:39 AM | #2 |
Welcome to the site Peter.
10-13-10, 07:50 AM | #3 |
Welcome Peter!
I look forward to seeing more of your DIY recuperator project when you get started. |
10-14-10, 05:57 AM | #4 |
Hello Peter
Welcome to ER!! |
10-14-10, 05:21 PM | #5 |
Welcome
What is a recuperator? |
10-14-10, 11:55 PM | #6 |
It's another name for a heat exchanger, usually of the air-air variety.
See this, for example: DIY ventilation heat exchanger |
