#1 |
![]() If you want to make your home more energy efficient, you can use an insulation blowing machine to install money-saving insulation inside the exterior facing walls of your home. Blown-in insulation will result in lower cooling and heating bills and make your home more comfortable all year round. Setting up an insulation blowing machine is not too difficult and is something you can do with the help of a few friends. Here is a simple step by step guide that will teach you how to set up and use an insulation blowing machine.
Sorry, new users are not permitted to post links in their signatures. |
#2 |
![]() Most home improvement stores will loan you a blower for 24 hours at no charge if you buy enough bags of insulation to use with it, they are really simple to use, plug it in, have one person feed bags in to it and the other person runs the hose, make hight marks before you start.
oh, sorry, you said walls... so this is wet blowen? dense pack? Last edited by Ryland; 06-29-10 at 08:29 AM.. |
