11-10-15, 01:00 PM | #11 |
Any chance we could get a review written Pinballlooking?
11-10-15, 01:48 PM | #12 |
I had preordered it but they kept delaying the android version. After a while I canceled my order. The Greenhouse cost were increasing and this is really just a nice to have.
I still want to get one it will probably just be a while before I get one. |
11-10-15, 03:51 PM | #13 |
I picked up one of these today
http://www.amazon.com/Seek-Compact-T...s=seek+thermal Haven't got to use it much yet. I'm getting ready to blow cellulose in all the attic space and wanted to see the difference.
שְׁמַע יִשְׂרָאֵל ה' אֱלֹהֵינוּ ה' אֶחָד |
11-13-15, 07:31 PM | #14 |
Memphis,
That's a cool product. I hope you post how well it works when it comes in. Len |
11-13-15, 08:33 PM | #15 |
This thing is AWESOME! Worth every penny! It has a focusing ring on the front to clean up the image, and I didn't do that with every picture. It has only gottten to 40F so far so it will be getting much colder and I can really tell where I need more insulation.
Car after not running for hours. Pictures of the house, the bright heat is not heat loss but instead it is where the sun has just been shining on the brick, this is just after dark. My chimney is SUCKING the heat out of my house! I need to really address this...... More pics of the outside of the house. This is the heat pump for the hotwater heater as it is running. The yorkie
11-13-15, 08:44 PM | #16 |
Top of hotwater heater while in use
Heat loss about bottom of door, I have magnetic weather strips on order. The side of my freezer while running. Heat loss above door and at edge of the ceiling, I have a lot of heat loss at the edge of the ceiling all trough out the house. Heat loss under my sink, this is the biggest disappointment..... Because I have a brick house NO IDEA how to make this better with out tearing up the whole house. (I am going to start another thread on all this, just explaining things) Chimney with no fire. Look at that chimney sucking all my heat out of the house. I started a fire tonight. I love the Seek! It has no other battery to have to charge and comes with an awesome case that I don't mind throwing in the tool box without worry of it breaking.
03-18-16, 12:23 PM | #17 |
Amazon finally has the FLIR ONE Thermal Imager for Android in stock.
http://www.amazon.com/gp/product/B00...ilpage_o00_s00 I ordered it and will have it in hand next Wednesday. I really wish I would have had it when it was very cold here. The greenhouse would have told me lots of things. I am looking forward to using it.
The Following User Says Thank You to pinballlooking For This Useful Post: | Daox (03-18-16) |
03-22-16, 11:50 AM | #18 |
It arrived today here a couple pictures.
My oldest son A picture of me Our cat Deep water culture in the greenhouse. I had just walked through the kitchen without shoes.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-23-16 at 01:32 PM.. |
