#21 |
![]() Looks good to me.
The Following User Says Thank You to Daox For This Useful Post: | jeff88 (04-03-15) |
#23 |
Lots of questions
![]() I agree. Easier and better for the planet! It's a win-win!
#24 |
Laughing Renovator
![]() Jeff good job! I learned some things with your solution. But for the other poster who said D rechargeables are hard to find, not so. Walmart's got them for $10. Ebay even cheaper.
#25 |
Lots of questions
![]() Thanks Leafgreen!
The batteries themselves aren't hard to find, it's the charger that allows for the size of the D batteries that is seemingly hard to find, at least in the States. Most only go up to the C size at most. |
#26 |
![]() For C and D batteries, I use the empty holders that came with my charger. Finding a charger that will hold that size is difficult, but putting large capacity AA batteries inside the adapters works well.
Just use the highest capacity and quality AA rechargeables you can. Even it doesn't last long enough, you could hack together your own holder that would hold 3 AA batteries for each D battery, basically making your own D battery out of AA Also an old cell phone battery should be around that voltage; you'd have to keep the old cell phone nearby (taped to back of can) as the battery charger holder |
