#1 |
Land owner
![]() Lows has a bunch of LEDs on clearance.
Some of the larger out door "90w replacement" flood LEDs are as much as $10 off the original price. They have everything from low voltage track light LEDs, to LEDs that you could put in a table lamp, out side porch light or indoor light fixture all the way to 10w LED floods. I want to replace all my current out door halogens with LEDs and expand what I have. Problem is the flood LED is the most expensive part. This will lessen the pain. I guess whats on clearance will depend on whats left in your store, if you live in a more hippy type area where every one is already buying LEDs the selection might not be so great. Wher I live power is cheap, so they haven't been big sellers. Power here might be cheap, but ultimatly I am cheaper so I replace 100w floods with 10w LEDs and replace 300-500 watt halogens with $10 dual flood lamp fixtures armed with twin 10w LEDs. Swaping a 300 to 500 watt fixture for a 20watt fixture, yeah I can see that paying for its self at some point. I work out side on projects well into the night. |
The Following User Says Thank You to oil pan 4 For This Useful Post: | Daox ![]() |
#2 |
![]() Thanks for the heads up I still need a couple LED flood lights.
#3 |
![]() Great, I'll be checking my lowes. I already replaced 6 of my outdoor cfl lights a few months ago. Kept a bright cfl on a switch by the bbq pit. I figure my timered outdoor lights run longer each day than any other lights in my house, so pay back should be sooner.
#4 |
![]() Although not exactly about clearance LEDs...
I just picked up a quantity of eight 60 watt equivalent bulbs at Ikea for $4.65 each. -AC
#5 |
Land owner
![]() Really cold temperatures kill CFLs, so might be time to switch your out side CFLs for LEDs.
The Following User Says Thank You to oil pan 4 For This Useful Post: | AC_Hacker (09-19-14) |
#6 |
Land owner
![]() Lowes is still getting shipments of these clearance LEDs in.
I went there to buy some yesterday and it looked like there were a lot more on the shelf. Maybe they will get marked down again. |
#7 |
![]() Home depot had some PAR38 1300Lumen LED's for $10.
#8 |
![]() That's great work. I'll check it.
#9 |
![]() Lowes has "regular" medium base 9.5w (60w equiv) on sale for $2.48 now.
Not quite the deal I got on CFLs at $.33 each a decade ago on some sort of special sale, but then again I'm almost finished with my CFL stash. |
The Following User Says Thank You to Boz86 For This Useful Post: | Servicetech (06-21-15) |
#10 |
![]() Home Depot had some Phillips 800 lumen 2 pack for $5.
