12-01-11, 07:24 AM | #141 |
Viking House
Hi, I was checking links to my website and found this forum, its been interesting reading!
I build Passive Houses in Ireland and the UK and we make our own HRV units that fit completly into the external wall. We fitted close to 50 units this year and they seem to be working well with higher return air temperatures than some of the PH Certified Paul units. We use Copper fine-wire heat exchangers that have 20km of wire in each heat exchanger. Last edited by Viking House; 12-01-11 at 07:30 AM.. |
12-01-11, 07:32 AM | #142 |
Welcome to the site Viking House. You make what we dream of! Would it be possible for you to share plans of your HRV units with us? Do you have any idea how efficient they are?
12-01-11, 08:01 AM | #143 |
Viking House
I have some data from a data logger but the file is too big to upload. I remember last January when it was -13 degrees C the return air temperature was +17 degrees C, and the house temperature was 19 degrees.
The Following User Says Thank You to Viking House For This Useful Post: | Daox (12-01-11) |
12-01-11, 10:13 AM | #144 | |
might not be something that a DIYer could duplicate in a home shop.. If it turns out that I have to install an HRV unit in my basement, I hope it won't turn out to be too expensive.
12-01-11, 01:55 PM | #145 |
Viking House
Well, I suppose I could sell you some heat exchangers at cost (€150 each plus transport) if you want to try them out?
12-01-11, 02:43 PM | #146 | |
Will there be issues with US electricity? -AC_Hacker
12-01-11, 03:11 PM | #147 |
Viking House
That €150 is just for the FiWi heat exchanger, not the box, motors or electronics! You can use US fans and control them with a potentiometer and make your own box, have you looked at EC fans?
12-01-11, 05:31 PM | #148 | |
Also, how does someone clean one of these units to remove fine dust, etc? -AC_Hacker
12-01-11, 06:25 PM | #149 | |
Viking House,
I just noticed that on your Viking House page, you said, Quote:
Do you have problems with the sonic boom when the unit is operating? Concerned, -AC_Hacker
12-02-11, 02:25 AM | #150 |
Viking House
I got the vapor equalization speed figures from one of the science guys on the UK Green Builders Forum who is usually pretty reliable, I tried to verify the by doing some Google searches but failed so I'll probably reword it and leave out the "at speeds of + - 500m/sec" bit!
Tags |
erv, heat recovery, hrv |
