#1 |
![]() I posted this 'shopped' picture on my new Sanyo Install thread,
and not one person has commented on my photo editing work.. ![]() ![]() Or, don't the guys who read about mini-splits have any sense of humor?? ![]() Cheers, Rich |
#2 |
![]() I see your blue R290 added to the front. Is that referring to the propane as a refrigerant in the other thread?
#3 | |
![]() Quote:
something about it.. "Hey, you aren't using propane? Are you?"... ![]() But, I guess nobody noticed it.. Oh well.. Cheers, Rich |
#4 |
![]() Or, this group finds it perfectly normal.
I tried to contain myself, but I escaped. |
#5 |
![]() Are you planning on using propane for this one? I know you talked about it but wasn't sure if you were actually going to do it.
#6 |
![]() "perfectly normal"?? You might be right! And no, I'm not going to use propane in this type of application.
I was thinking about R290, if I used an outdoor HX (with the hot water scheme). |
#7 |
#8 |
![]() Dang! I need to get a life! (Well, it is raining today)..
I guess this is what happens when you retire too early.. ![]() |
