05-07-15, 10:05 AM | #1 |
A Self Watering Rain Gutter Grow System
Ok I saw this idea researching aquaponics.
I love this idea using 5 gallon buckets it keeps you from bending over so much. Low weeds and self-watering very low cost. Make sure you use a RV lead free hose if you do self-watering. |
The Following User Says Thank You to pinballlooking For This Useful Post: |
05-07-15, 10:35 AM | #2 |
I think a cover to keep mosquito out would be useful.
05-08-15, 07:01 PM | #3 |
Very cool and simple idea. I like it.
08-26-15, 10:58 AM | #4 |
This system is much like the auto pot system. The main difference, besides the obvious, is the fill valve. The auto pot system has a valve that lets the trough draw down mire before refill. With a clean water supply, these rigs are pretty much zero maintenance all grow season. Just add nutrients to the top when pruning or harvesting plants.
I have used a rig just like this for starting cuttings and seeds. I cut strips of xps to float in the gutters, then just cut holes in the xps the size of whatever. Works like magic. |
