01-05-14, 12:18 AM | #1 |
Cheap Renovator
Motion detector outdoor lights
I have an outdoor motion detecting light on my deck. Since I have a an outdoor cat, it lights a few times a night. I used to have Halogen floods 60Watts times 2 installed.
Recently changed to LED Floods from home Depot, they lasted 1 month then burned out. Did not save packing or receipt from Home Depot. Anyone else having issues with outdoor Led bulbs? |
01-05-14, 06:21 AM | #2 |
You have two issues that can cause this problem: The first could be bulbs not ment for the stress of outdoor use. The second is the motion detector. When using LED or CFL bulbs with a motion detector you MUST use "Dimmable" bulbs. Reason being, motion detectors tend to not deliver the full current to the bulbs and also will often flicker to almost on with minor motion that does not quite meet the "on limit" set. Incandescent bulbs don't mind this and simply flicker dimmly. But the electronics behind the LED and CFL bulbs burn up quickly if they are not designed to be dimmable.
The othe strange issue I've been having with LED bulbs used with my motion detecting flood out back is the detector has a built in timer. This timer works fine with incandescent bulbs, but shuts off at inconsistant times with LED or CFL bulbs installed. Anywhere from 3 seconds to never. I've tried all positions of the setting switch with the same results. (1 minute, 5 minute or always on) |
01-05-14, 09:15 AM | #3 |
An alternative would be to make some sort of blocking plate so that your motion detector can't see that close to the ground. This would stop it from coming on due to the cat, but when a person or car comes by, it turns on. It would take some adjusting I'm sure, but its simple and cheap.
01-14-14, 12:11 PM | #4 |
I put 4 cfl bulbs in my daughter's ceiling fan and they flickered like crazy. I replaced 1 of the cfl's with an incandescent and it now works fine.You might try replacing one of the led's with an incandescent. Kind of cuts back on your energy savings though.
If there are two ways to do a job always choose the hardest; it'll take twice as long but you will learn twice as much. |
01-15-14, 04:07 AM | #5 |
It is interesting that you say that. I had a similar experience with LED christmas strings. I had lit my tree with 3 strings of LED lights and found it way too bright. So I put the tree on a power-strip with a dimmer but then the LEDs would not light. I added one 4 watt incandescent night light to the strip and the whole thing worked as expected.
01-15-14, 07:19 AM | #6 |
Fascinating! I too have a ceiling fan where I replaced the four incandescent "calabra" lights with CFLs. They flickered. I redid the wiring thinking I must have screwed up the wiring when I put the ceiling fan in . . . but all wire nuts were in place as expected. Re did them anyway.
Still flickered and it is VERY distracting! So I put one of the old incandescent bulbs back in - the flickering stopped. I simply do not have an explanation . . . . There is obviously an oscillation that occurs with the CFLs and a fixed resistance stops it. But why? Steve
12-15-14, 02:19 PM | #7 |
Home-Wrecker
This thread got me wondering - "How much energy does the motion sensor use?"
One of the common thoughts on motion sensors is that they save you money on your electric bill - instead of having a light on all the time, it simply comes on when it senses movement. But how much energy goes the sensor use? In other words, would it be better to simply have a plain on/off switch and only turn the light on when you need it?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
12-15-14, 02:34 PM | #8 | |
[*] When I say "they were on" I mean the motion sensors were on but not the lights Last edited by SDMCF; 12-16-14 at 12:48 AM.. Reason: Add clarifying footnote |
12-15-14, 04:48 PM | #9 |
Home-Wrecker
I figured that they would PROBABLY measure pretty low, but it's also one of those really weird things that's easy to overlook when trying do a DIY home energy audit!
12-25-14, 01:09 AM | #10 | |
Using a fixed purely resistive load to snuff out this inductive nonsense is a cheap trick that works really well. Last edited by oil pan 4; 12-25-14 at 01:15 AM.. |
