Go Back   EcoRenovator > Improvements > Biofuels
Old 01-02-14, 07:36 PM   #1
Default not exactly a biofuel thing but.....
Man invents machine to convert plastic into oil - YouTube
Why haven't done stuff like this before?
Old 01-03-14, 08:12 AM   #2
I saw this on ecomodder a while back. It looks like its a pretty energy intensive process.
Old 01-03-14, 08:19 AM   #3
It just looks like a glorified distiller but I cannot figure out how it de-polymerizes the plastic? It has t be be broken right down so that components don't bugger up whatever engine burns the fuel. It doesn't seem to use much electricity to do it either.
I want one....
Old 01-03-14, 08:41 AM   #4
I can't see the video here at work, but I remember seeing some temperature gauge on it, and it read 400 (not sure if it was F or C).
Old 01-03-14, 08:43 AM   #5
I suspect it was C, very few F countries around.
Old 02-15-16, 04:42 AM   #6
Redmohawk
Most plastic and rubber setups run above 550 deg c , the hotter the temp the more long chains are broken down into shorter chains. Non condensable Gas volumes produced increase and condensable gasses decrease . From car tyre rubber everything from Butane to heavy diesel fuel oil is produced.
Those interested in the processes should google tyre/plastic pyrolysis .
Redmohawk is offline   Reply With Quote
Old 02-15-16, 05:33 PM   #7
Anyone who can distill alcohol can perform this process. Heat up the plastic in a closed container, catch the vapors in a water bubbler. Presto, diesel fuel is rendered! The rendered product can be further refined into kerosene or jet fuel.
Read this article:
Whole Systems Foundation - Recycling and Pyrolysis of Plastic
If you didn't know already, plastic pollution is a growing global problem. We are using one of the most durable substances ever invented as a disposable, single-use wrapper. Waste plastic has been finding its way into the food chain, and it has been found to act as a sponge for nasty, persistent organic chemicals. The American government has taken notice by banning the use of ground plastic as an abrasive in health and beauty products. This was one of the very few bills in recent times that did not garner opposition from anyone in Congress.
The process is actually being used by concerned industrialists. Typical yield is 3 to 5 barrels of oil per ton of waste plastic. In countries like Japan and China, this process is being employed on a large scale to both reduce waste streams and provide diesel fuel. It is a much more environmentally responsible process than the conventional open burning of waste. In America, cash is king, and this process isn't highly lucrative. As expected, we are selling our plastic waste to Japan and China. For a lot less than barrels of oil.
