#1 |
ECO Blogger & DIY'er
![]() It was time to clean behind my computer so I took the opportunity to install a Universal AutoPowerOff from SavePower. It's a power strip that kills the computer accessories when the computer is shut down. Saves some power, but for me mostly a question of laziness.
![]() Just a idea if anyone of you has large monitors etc that drains a lot of electricity when in standby mode. Also a little DIY ![]() /Caffe
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#2 |
![]() How much power are you saving by using the power strip?
I know my entire computer setup uses about 10-11W while off or in standby. A new smart power strip is on the list of things to get.
#3 |
![]() I haven't done any measurements but a kill-a-watt-meter or similar is my next purchase, will do a test then!
