Old 11-10-10, 10:51 AM   #1
st2288
Default Cheap panel?
I bought 2 panels from 350.00 each after my offer. so it's 1.75 a watt.
CanadianSolar CS 6P-200 PV Module Never used - eBay (item 150473546772 end time Nov-26-10 07:04:17 PST)
He's on long island. so I save the shipping charge.
I dont know what I will do with it, since I cannot connect to my inverter eventhough it is not at the max yet. I used Sharp panels and this is made by Canadian solar.
May get some enphase to wire into my panel.
st2288 is offline   Reply With Quote
Old 11-10-10, 10:58 AM   #2
Sounds like a great deal.
Everyone I've talked to using the enphase converters is quite happy with them.
What inverter are you already using? I don't remember you talking about a PV or wind setup?
Old 11-10-10, 11:23 AM   #3
st2288
I have 7.99 k system. it consides with Sunnyboy 5000 and 4000 inverters into 2 strings configuration.One string is 5.17 kw and the other is 2.8kw.. Too bad I just can't attach the two panels to the 2.8kw string (two different type and spec)
Old 11-10-10, 05:08 PM   #4
Good deal!! Nice find.
I think the simplest way to get these new panels doing their share, is to go ahead
and spend some more money on a pair of Enphase inverters.
Or, check out the new dual-panel Enphase GTIs..?.
I'm pretty sure you new panels are on the Enphase compatibility list..
Downloads - Support - Enphase Energy
Old 11-10-10, 05:19 PM   #5
st2288
I made the deal with the seller.. they have 72 panels ..need to get rid off it asap..
I got 3 for 900.00.. and saw a M200-32-240-S02 enphase inverter for about $100.00 w/shipping. But can't find anything whether the 2 are compatible. I even called enphase.. they don't know..
Looking at the spec. I don't think they are compatible. The Von voltage it too hight for the inverter..
The problem now is where to mount them.. my roof is max out.
Old 11-10-10, 06:48 PM   #6
Default M200-32-240-s02 ??
"I got 3 for 900.00"?? That's $300 each?? WOW!!
Now, you are making me want to drive down to Long Island!!
Humm, I wonder if six of those would fit in the back of my Escape.?.
Yeah, your PV voltage is too low.. 30v isn't gonna hack it..
Enphase Micro-Inverter M200-32-240-S02 MC4
"Peak Power Tracking Voltage: 44 volts to 65 volts"
Your PV should be near the top end of the MPPT range (IMHO)..
Do you have any good spots in the backyard for a little post mount?
Old 11-10-10, 07:22 PM   #7
st2288
I agree .. I need the new type Enphase Micro-inverter M190-72-240-S12...
I am thinking about mounting on my deck cover. I will include some pict tomorrow. But i think I may need a permit.. If i mounted on a rack on the lawn.. I maybe able to get by.. need to check the solar coverage tomorrow.
I am sure the guy is willing to deal..
Old 11-10-10, 07:39 PM   #8
Default Look around, there might be a few places
That need some over-head shade..?.
st2288 (11-10-10)
Old 11-10-10, 07:43 PM   #9
st2288
That's exactly what I like... but try to find the hardware is almost impossible...
Old 11-11-10, 05:45 AM   #10
Make your own racks out of wood?
