11-30-10, 02:20 PM | #51 |
Do you mean: the edit function, or dinner with the female unit?
11-30-10, 11:32 PM | #52 |
Both! Work is progressing smoothly though. Got the individual entry edit working, just need to put in the user checks and then I'll put it live
12-01-10, 02:32 AM | #53 |
Editing links currently up random places. Will move on to linking the individual entries under the home display.
12-01-10, 04:33 AM | #54 |
Editing home details works, but it appears I can edit Strider's home, too. I didn't try saving, though.
No entry edits yet, not visible on "home" page. |
12-01-10, 08:44 AM | #55 |
Looks good except for the editing other peoples homes.
It would be great to move the entries for each home to that specific home's own page so you can see just the entries for that specific home.
12-05-10, 07:42 AM | #56 |
Ah. I suppose that's an issue. You can see the edit form but it shouldn't overwrite the data anyway. Working on tim's suggestion at the moment.
12-15-10, 08:33 AM | #57 |
I see Ben has made some updates to the energy tracker. I think its getting close to being useful.
I suggest adding another field for "Renovations & Improvements" where you can list things you've done to the house. Also, it and the notes field don't recognize returns, so it slaps everything on one line. Both of these fields need to be larger than the current notes field. Also, when you view a specific home it doesn't show the date, HDD, CDD, or notes field for each entry.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 12-15-10 at 08:58 AM.. |
12-15-10, 08:58 AM | #58 | ||
Nice
I can still edit other houses, though. Quote:
12-15-10, 09:07 AM | #59 |
Ah, thanks for pointing that out. I think the date should be moved to the front (left side) of the entry display info.
The view link will become an edit link eventually. I think its a carry over from earlier versions of the program.
12-15-10, 09:28 AM | #60 |
You can now add an image of your house.
