03-22-17, 05:17 PM | #31 |
havent measured changes but water temp iw always around 55f. I have a 10 ton and a 5 ton unit running off it. I dont know what flow rates are for the units but I know the well was tested at 12.5gpm when it was installed 30 years ago. Well dept is about 75 ft and i use a 1/2 hp submerged pump and it supplies the whole house and 2 geo units no problem.
[QUOTE=slippy;54055]@simenad: Have you measured temperature changes over time? What is your tonnage and flow rate? What kind of pump(s) are you using? Does the injection well have any problem taking the water?[/QUOTE] |
03-22-17, 07:47 PM | #32 |
Well, I'm jealous!
I'm also surprised that you are getting the heat exchange that you need with whatever flow rate you get from the 1/2hp pump. For 15 tons of HVAC, I thought you would need about 45GPM. Most of the units I have seen specify 3GPM/ton. But, that makes me slightly more optimistic about my plight. |
The Following User Says Thank You to slippy For This Useful Post: | simenad (03-23-17) |
03-24-17, 08:25 AM | #33 |
Jumping on the internet, looking around, and taking random recommendations and rules of thumb as law is not a good plan for success, as you have hopefully learned by now. In the really real practical world, especially when taking on DIY projects, Murphy's law dominates everything if it can. In all experimental/amateur projects, be prepared to fail multiple times. Even in many professional endeavors, trial and error is an essential part of the process after you leave the drawing board.
Even hiring a tradesman to do the tricky parts of the job doesn't guarantee success. All it does is relieve you of time and money before that portion of the project is completed. Instead of taking days, weeks, or months and a few relative dollars to reach a certain point, it takes many more dollars and much less time. In this case, you would most likely need to acquire (or have acquired) at least one or two permits before a pro could commence drilling your well for you. This introduces a whole new set of challenges and expenses to the project. It's your project, so where to go from here is completely your decision to make. No one is going to bash you if you decide to throw in the towel. It seems to me that you have most everything you need to continue on site, and favorable ground conditions to eventually produce an acceptable source well. Your first attempt at drilling did not yield an acceptable end, and now you question everything. Sounds like Phase one of three or four to me. Whether Phase two will commence and how is yet to be determined. My boss would tell me to deal with it and hurry the #$%& up, I ain't got all day. That's the thing about being your own boss: you have to make all the hard decisions and keep yourself convinced and motivated (for free). Plus you get to pay for everything, for better or worse. |
The Following 2 Users Say Thank You to jeff5may For This Useful Post: | DEnd (03-26-17), Geo NR Gee (03-24-17) |
06-12-17, 07:16 PM | #34 |
Go to lowes n buy a blow up balloon sewage uncloger . Not sure of the name . It's black n fills with water to jet clogs . Put it so it back feeds the well inside run it 20 mins . Then feed air into bottom of the well . Let it run . Your gpm will in crease . Sounds like u havent developed it . More u pump a well . Better it gets....... Or... u just set the screen in the wrong spot . In that case . It won't produse quater as much
06-12-17, 07:24 PM | #35 | |
I see u fabricated your screen ? This is a possible problem for u if u made it with a hacksaw n the slots are letting in a lot of sand it will mess up your pump. Screens 2 inch are really cheap 20 bucks at lowes for 5 ft with th shipping |
