Old 11-10-16, 05:54 PM   #11
I finely got it going and I like it.
The only thing don't like is it not kicking on at real low flow.
I may consider putting a tiny electric tank water heater under the sink or a small tankless that handles low flow really well.
Old 11-10-16, 06:11 PM   #12
Mine has an Activation Flow Rate: 0.40 GPM. When I was searching for a unit I looked for a low Activation Flow Rate.
You can make your sinks flow a higher rate.
Old 11-10-16, 06:44 PM   #13
Pinball,
Remind us of the specific tankless water heater you have. Really 0.04 GPM? That is a trickle!
Old 11-10-16, 06:56 PM   #14
Steve that was a typo it is about 1/2 gallon that is about as low as I was looking for. .40 GPM
(sorry that would be crazy low.)
T-H3-DV-N - 199,000 BTU Natural Gas Indoor Condensing Ultra-Low NOx
Spec sheets.
http://www.takagi.com/media/19483/24...TRGSS01512.pdf
ULTRA-LOW NOX 0.95 ENERGY FACTOR
Power Direct Vent Design
• Exhaust, 3” PVC Venting up to 70 feet or
4” PVC Venting up to 100 feet
I have been very happy with it. The intelligent circulating pump really helps. In my bathroom by the time you use the water warm to hot water is there.
Old 11-10-16, 11:13 PM   #15
The kitchen and bathroom sinks kick it on no problem. I think kitchen sinks flow like 1.5gpm and a bathroom sink does around 1gpm.
Old 11-26-17, 10:43 AM   #16
Mini
Mini's Avatar
I looking for info about how to flush my tankless water heater and I came across this site. I know the opinion that еoo much of calcium and mineral deposits can reduce the life of the tankless water heater. Regular flushing is quite beneficial for its longevity and improve its efficiency. How do you flush your water heater? What can you recommend?
Mini is offline   Reply With Quote
Old 11-26-17, 02:15 PM   #17
I added additional valves when I installed it for this reason.
I have a few pumps I could use to circulate water with.
For the chemical I figured I would get some nitric and phosphoric acid mixture from work.
Old 11-27-17, 12:24 PM   #18
I installed the valves on my hot water heater as well when I installed it. I've honestly never used them. We have decently hard water that is softened.
Old 11-27-17, 12:30 PM   #19
I installed them as well and have never used them.
I do plan on it I bought the vinegar a year ago.
But the hoses I had for the job I used for another project.
hot water, maintenance, tankless heater, water heater
