10-05-12, 12:46 AM | #11 |
I was thinking a better set up would be too keep the fridge doors the same height but add the compressor and condenser on top after all our ceilings are 8 ft high.
10-05-12, 05:55 AM | #12 | |
2012
good enough to monitor
Google Image Result for http://images-en.busytrade.com/211942800/Energy-Saving-Plug-in-Power-Monitor.jpg I think I need to look at this now !! |
10-05-12, 06:37 AM | #13 |
"mnrenovator are you sure your's blows air out the front?"
Yes, when I cleaned the coils a couple of months ago I took a good look. The coils are the full width of the refrigerator compartment. There is a fan that pulls the air through the coils and the exhausts it under the freezer side and out it flows out the front. Basically the freezer side is like a duct. This also helps with passing the warm air over the defrost water to evaporate it out quicker. The back of the fridge has no vents its a solid chunk of brown masonite or similar material in that area so the air doesn't have a way of readily going to out the back. |
10-05-12, 08:08 AM | #14 |
Looks like I'm going to have to pull my fridge out too now! I don't know if the coils are on the bottom or back... I too couldn't put insulation around the sides of my fridge, but I could probably put some on the back/bottom.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 10-05-12 at 08:12 AM.. |
10-05-12, 12:03 PM | #15 |
I have the math on improvement made it turns out to be a 38% improvement.
10-05-12, 12:16 PM | #16 |
How are you measuring the fridge on cycle time?
10-05-12, 12:31 PM | #17 |
I timed the run time and off duration with the wall clock for a week, compiling a 10 page collection of run times in the process.
It is a high resolution measurement. Also in the morning when its 15c inside the fridge will stay off for 3 hours and run for 30 min. Last edited by ecomodded; 10-05-12 at 01:33 PM.. |
10-05-12, 01:07 PM | #18 | |
I tested the fridge with just the bottom of the fridge from the kick panel to the compressor/condenser insulated for a few days and noted a shorter run duration consistently of 2 - 3 minutes and a 10 -15 minutes longer off time. |
10-08-12, 12:49 PM | #19 | ||
10-08-12, 03:23 PM | #20 |
Haha it was dedication!, I actually tested each layer of insulation and its effect, the on time shortened and the off time lengthened predictably with each layer, i may yet add more layers down the road, but first i want to conduct more tests.
Your TED will be liking the fridge insulation, I also wanted to mention that if you could, insulate the refrigerators top as the freezer section could use the extra insulation. |
