06-27-17, 12:54 PM | #21 |
Hey Sully01,
I'm a retired software engineer, micro code, power on self tests on many types of disc drives, tape drives, storage controllers, printers. |
06-27-17, 12:58 PM | #22 |
I have been studying hot water floor systems since I retired in 99.
Have designed & installed 4 systems, this is my 5th. Learn on every one. |
07-07-17, 02:53 PM | #23 |
I have made a little progress:
Main lower level of house walls have been poured: 8" concrete x 10' high, a 30' x 48' rectangle walk out basement. I had the windows bucked in so that windows & doors sit into a 5.5" x 1.5" recess all around on the outside, so if they ever leak water goes to outside. Windows & sliding doors are Andersen Series 100 Fibrex Attic trusses are on site and I have added the 16" gable end overhangs. The gable end trusses have the 2x4's laid flat, on them I glued & shot 8 penny nails 1/2" CDX plywood, primed all seams with Glidden Gripper, taped with 3-M all weather tape, Next layer is 30# roofing felt, next layer a drainage plane of 1/4" Benjamin Obdyke Home Slicker + Typar, next layer is 1/4" 4x8' sheets of James Hardie exterior cement board with all seams taped with cement board mesh tape, next layer is a base coat of Styro TuffII synthetic stucco, now they are ready for the crane to hang, but 1st I have to backfill around sides & rear, before that I have to have the footer drainage system inspected, then install the 1" PEX water line in, the 4" sewer line out, & the 200 Amp power line in, the 1,000 gallon cistern & float switch wires, inside the cistern I will put a 300' of 1" pex to be used for cooling upstairs in summer. Whew! just getting started |
The Following User Says Thank You to buffalobillpatrick For This Useful Post: | Daox (07-07-17) |
07-07-17, 04:16 PM | #24 |
Congrats on getting started.
We need picture!
The Following User Says Thank You to pinballlooking For This Useful Post: | buffalobillpatrick (07-08-17) |
07-07-17, 04:56 PM | #25 |
Awesome progress! Ditto on the pictures.
The Following User Says Thank You to Daox For This Useful Post: | buffalobillpatrick (07-08-17) |
07-08-17, 01:30 PM | #26 |
As my computer crashed, I'm on a public library computer.
All my photos are on my Iphone. I selected 5 pics on Iphone & am in VERY SLOW process of them hopefully uploading, seems to be choking at 2 bars signal strength. |
07-08-17, 03:17 PM | #28 |
1st pic is above rear of house looking East, the front door in middle is 8' high, the windows on either side are 7' x 5', the sliding door on the right (South) is 8' x 8',
the rear (West) bedroom window is 4' x 4' egress, the front (East) 40% 12'-8" wall is on a 32" step down footer, as this dirt (haha) is decomposed granite (small rocks) and dry, this is all I had to go down by IRC code, the space inside the wall gets 7-8” thick type 2 EPS 2nd pic shows the 27' retaining wall 10' tall with a buttress on back side (dead man), on front (East) side will be parking & BBQ area by slider. 3rd pic shows the North wall buttress, required by my Structural Engineer due to 48' wall length & 8' of back fill. 4th pic shows the front (East) gable end (bedroom) with a 6' x 6'-8" sliding glass door opening out to a 12' x 20' balcony/carport. The lovely purple color is what I got when adding dye to the Styro TuffII, not what I was shooting for, so I call it a base coat. 5th pic shows the rear (West) gable end during assembly, has a 4' x 4' slider for a 2nd upstairs bedroom egress. Last edited by buffalobillpatrick; 11-05-17 at 10:32 AM.. |
08-19-17, 03:39 PM | #29 |
BuffaloBill I like your work Im planing my first build for next year using ICF's.
have you considered using rigid insulation on the outside of the basement ? it would be first on my list so thought I would bring it up.
The Following User Says Thank You to ecomodded For This Useful Post: | buffalobillpatrick (11-05-17) |
08-26-17, 01:43 PM | #30 |
I agree with Martin Holiday's + and - recent comments on this Greenbuildingadvisor.com
My inner layer is 4" of Polyiso foam which can't be in contact with earth (gradually absorbs water) http://www.greenbuildingadvisor.com/...-basement-wall http://www.greenbuildingadvisor.com/...ers-spray-foam Trying to upload latest pics on cell phone is not working, hung, 2-3 bars signal strength got this message "your submission could not be processed because a security token was missing" I give up I found that I could upload 1 pic at a time Last edited by buffalobillpatrick; 11-05-17 at 10:20 AM.. |
