07-10-13, 02:45 PM | #1 |
Is it worth reviving a *old* B&D battery mower?
I've inherited a very old Black & Decker battery mower - it's a 12v model that I had not even seen before. The wheels are pretty wonky, and the previous owner blocked off the side chute to make it into a mulching mower.
Has anybody converted one of these to use a standard car battery; or any other method to keep using one of these mowers? |
07-10-13, 02:54 PM | #2 |
If the charger works (or you have any old 12V charger), all you probably need is a battery... should be an easy fix. Darin did this two years ago:
http://ecorenovator.org/forum/lawn-g...ker-mower.html
The Following User Says Thank You to Daox For This Useful Post: | NeilBlanchard (07-10-13) |
07-10-13, 03:16 PM | #3 |
I do have the charger, yes. Thanks for the reminder on the old thread. That is similar to the mower I have.
07-11-13, 06:56 AM | #4 |
A normal car battery will work, but the gel batteries like that seem to handle deeper discharges if I remember right, they also tend to be easy to find a direct replacement for the battery.
On my electric lawn mower I replaced the gel batteries a few years ago and they are still working ok, 4-5 years of use is common, but when they are in need of replacement next I plan to go with Lithium, I haven't found anything much cheaper that looks better then PingBattery LiFePO4 Battery packs for Electric Bicycle e-Bike & Scooter, Lithium Iron Phosphate Battery but he doesn't have any 12v packs, a lot of other mowers are 24v or 36v. |
The Following User Says Thank You to Ryland For This Useful Post: | NeilBlanchard (07-15-13) |
08-08-13, 10:32 AM | #5 |
Did you ever spend time reviving the old mower Neil?
08-09-13, 10:27 PM | #6 |
I have not been able to even look at it again.
08-10-13, 03:26 PM | #7 |
Neil,
Why don't you just rip it's heart out and put in its place, a nice reliable AC induction motor? It will give you trouble free service many times longer than a battery power setup ever will. Cords really aren't so hard to get used to. A GFI breaker for the circuit you will use is always a good idea, although I built one that never got that luxury, and in all the years of use, I never felt a single tingle. Be a man Neil, rip its little heart out... Sincerely, -AC
08-11-13, 07:07 AM | #8 |
I own two plugin electric mowers! One has a 300' cord, and the other has a 200' cord.
08-11-13, 09:54 AM | #9 | |
There comes a time in every mans life when he has to ask one of the most important and difficult questions of his life... Do I own my lawn, or does it own me? ...I mean, my lawn is maybe 40' x 15' and I consider it to be a hateful, dreadful, repetitive, soul sucking burden. In fact I am in the process of turning my front lawn into a vegetable patch as soon as possible. The next door neighbors were looking askance at me a year ago, for not doing my part in maintaining the illusion of an English dream lawn. So I gave them some tasty home grown heirloom tomatoes, and now, the neighbors on both sides are also turning their lawn-burdens into lovely, productive gardenettes that are even more successful than mine. Liberation!!!! -AC
08-11-13, 05:53 PM | #10 |
I agree - the 200' cord is more than enough for my yard, actually. The 300' cord is for the Friends Meeting (Quaker) lawn which is about 2.5 acres - and there are several plug locations.
