#41 |
![]() I've been doing more experimenting with the 'stalled fan' issue mentioned previously.
My current solution is to add an integer number to the PWM_Value, this way when the CO2 level drops, as when I'm away from the house, the fans will be kept just barely turning. In the unusual event that a gust of wind happened to be exactly enough to stop the fan, I wanted the fan to be able to restart, at a very low speed, even when CO2 values were at their minimum, which means that I need a PCM_value of 92 minimum, which translates to a minimum duty cycle of 36%. The range of CO2 ppm that is conveyed by the sensor's analog value is: 0 volt = 0 ppm 4 volt = 2000 ppm ... and this will yield the following PWM_Value in my Teensy: 0 ppm = 0 PWM_Value 2000 ppm = 256 PWM_Value So, I set up the ratio: (300 ppm) / (2000 ppm) = (x PWM_Value) / (256 PWM_Value) Therefore: (x PWM_Value) = ((300 ppm) * (256 PWM_Value)) / (2000 ppm) So: x PWM_Value = 53.6 (when ppm is 300) But the fans have a minimum start-up threshold of 90 PCM_value, so: 90 - 38.4 = 53.6 (rounding up to 54) I'll 'pad' my PCM_value by adding 54, as in the code below: Code:
int CO2_ReadPin = 38; // initialize pin 38 for analog voltage in int PWM_WritePin = 14; // initialize pin 14 for PWM int CO2_Value; int PWM_Value; int DutyCycle; int ppm; void setup() { // BEGIN SETUP pinMode(PWM_WritePin, OUTPUT); // Make PWM_pin (AKA: pin 14) an output pin int CO2_Value = 0; // variable set to zero int PWM_Value = 0; // variable set to zero int DutyCycle = 0; // variable set to zero int ppm = 0; // variable set to zero Serial.begin(38400); // Initialize Serial Monitor } // END SETUP void loop() { // BEGIN LOOP CO2_Value = analogRead(CO2_ReadPin); // read Teensy input pin 38 unsigned int ppm = ((unsigned long)analogRead(CO2_ReadPin) * 2500)/1024; // calc ppm Serial.print("CO2 level = "); // print ppm to serial monitor Serial.print(ppm); Serial.println(" ppm"); PWM_Value = CO2_Value/4; // Scale CO2_Value (range = 1024) to PWM_Value (range = 256) analogWrite(PWM_WritePin, (PWM_Value + 54)); // Write PWM_Value to PWM_WritePin Serial.print("PWM_Value is = "); // print val to serial monitor Serial.println(PWM_Value + 54); DutyCycle = (100 * (PWM_Value + 54) / 256); // Calculate DutyCycle Serial.print("PWM DutyCycle = "); // Print DutyCycle to serial monitor Serial.print(DutyCycle); Serial.println("%"); Serial.println(); // print null line to serial monitor delay(1000); // delay 1 second before repeating loop } // END LOOP Best, -AC
#42 |
![]() I see the range specified, but are you going to calibrate the sensor? I would assume you could just use welding CO2 if you decided to calibrate it, correct?
#43 | |
![]() Quote:
I'm really not so concerned with calibrating, since I can easily use software to tweak the ventilation rate to suit. Right now, the PCM duty cycle is varying linearly with respect to the measured CO2 level. I realize that I may need to shape the curve (log, linear, exponential) if need be. The box I put it in and the friction characteristics of my HRV core will have a big influence on how I need to shape the curve. I didn't think I mentioned this before, but I bought two pairs of fans, one pair is about 5" in diameter, 12 volts & 400 ma. The other is maybe 6+" in diameter, 24 volts, 750 ma. I'll just have to see which pair works out best. But returning to your question about calibration, I currently have two CO2 sensor rigs that I am running, one is a commercial assembly, the other I built myself, using the Teensy, both use the Telaire 6004. They're located in different parts of the room, but I have found that if the air is constantly stirred (ceiling fan) the two read within 3% of each other. I'm pretty satisfied with that. Best, -AC
#44 |
![]() 3% is really close. I didn't realize you had two different sensors, so that makes complete sense not to even bother with calibration.
#45 |
![]() I've been searching for a reasonable humidity sensor, and there are quite a few available.
Seems that Honeywell has quite a few, and Sparkfun & Adafruit have them in stock. It could be useful to be able to measure temperature and humidity with the same sensor (many of the sensors do this), but I have several 1-wire temperature sensors in my parts kit and I trust their performance, so combined sensors is not by itself a deal-maker. Looking over the specifications, I see that almost all of the humidity sensors require 3.5 volts. There are cheap surface mount voltage regulators available, but it's just more to do. I do have a combined humidity/temperature sensor (Sensiron SHT-15) see photo below: This is a full size photo on my computer screen, hold a penny to your screen, see if it works on yours... But this sensor is really awfully small, and to use it will require micro-surgery and some kind of breakout board. Even though I recall that there is an Arduino library for this chip, it's a bit discouraging, even though I have the part I need. Sparkfun & Adafruit do have sensors already mounted on breakout boards, so that's a plus right there. But then I came across this on Ebay... It's still pretty small, but no microsurgery required. It has a tiny adapter board already attached with the required resistors, etc. and the pin-out is VCC (5V), Ground, and signal. The language was a bit mincing, as though it had been run through a Chinese meat grinder, but I have a suspicion that this is a 1-wire device and that both the temperature and humidity information are available on the center pin. Things will get simpler if that's the case. So, (...drumroll...), I sent $6.64 to China to see if I'm right... I do realize that this is a big gamble, but I guess I'm just reckless that way. Best, -AC
#46 |
![]() We just tested the DHT11 today, seems ok.
Here is a 2" cycle reading: TEMP UMID Requesting data...Got Data 20.70C 52.00% Requesting data...Got Data 20.60C 51.90% Requesting data...Got Data 20.70C 52.00% Requesting data...Got Data 20.70C 52.00% Requesting data...Got Data 20.60C 51.90% Requesting data...Got Data 20.60C 51.90% We'll gonna hook this up to a hot air solar panel soon to control the fans speed. Stay tuned ![]() |
#47 | |
![]() Quote:
Do you have a schematic of your hook up? Are you using an Arduino? Wanna share your code? I want to hear the details. Best, -AC
#48 |
![]() I'll ask my buddy who's currently working on it as he doesn't speak English.
I my self know nothing about Arduino, all I can tell you for now is that we're trying to get the hottest air out of the solar panel. We were thinking of something like this (using one sensor inside the panel and another inside the house): Panels inside temperature above 20°C: system ON if the panel's inside temperature is higher than the house's: increase fan speed if the panel's inside temperature is lower than the house's: decrease fan speed if the panel's inside temperature equals the house's: maintain fan speed Panels inside temperature below 20°C: system OFF |
#49 | |
![]() Quote:
#50 |
![]() I've liked the DHT11 (aka RHT03) for household humidity measurements. But the spec sheet I have has shows that they 'want' a RH of 20%-90%. I'm not sure how they'd do in a condensing environment longterm, although it does say "* Avoid using the sensor under dew condition."
The spec sheet says its a resistive-type humidity measurement sensor. I'm guessing its not the salt kind, so conductive polymers most likely. Not sure what codensation would do to the sensor over time. |
