12-02-11, 06:28 AM | #191 |
Dan_LASER
12-02-11, 06:29 AM | #192 |
Dan_LASER
I apologize but I must have 15 posts so I can give you a message
12-02-11, 06:31 AM | #193 |
Dan_LASER
12-02-11, 06:32 AM | #194 |
Dan_LASER
expect a message from you
12-02-11, 06:58 AM | #195 |
Dan_LASER
sorry for my English
12-02-11, 07:10 AM | #196 |
Hello Daniel
Good Morning!
Here is the tracker circuit that I'm using. It's made by Red Rock and works very well. LED3X Solar Tracker Assembly This tracker must be used with a motor that has Limit Switches. LED3X Solar Tracker Assembly
12-02-11, 07:26 AM | #197 |
Dan_LASER
Thanks a lot
solar tracking in the pictures is not good what happened? |
12-02-11, 07:33 AM | #198 |
Dan_LASER
What happened to your cycle of the pictures above?
Relay circuit axicom |
12-02-11, 07:42 AM | #199 |
Dan_LASER
What happened axicom Relay circuit?
not working |
12-02-11, 07:59 AM | #200 |
After many cycles, the relay contacts wear out. Operation become erratic.
I replaced bad relay, but gave up on board after second failure. If you decided to use relays in a tracker, make sure to install sockets, so they will be easy to replace. (Without using soldering iron).
Tags |
electric, solar, tracker |
