#11 | |
![]() Quote:
At first, I was worried about not having battery backup on my timer.. http://ecorenovator.org/forum/conser...ent-timer.html I was interested in the INTERMATIC too. But wondered if my wife would be able handle the programing etc, if I wasn't around.. But, our grid seems be getting more reliable, or our weather luck is amazing. (We just dodged a hurricane). After a grid failure this spring, (while we were not at home) I noticed the burn started up at the wrong time, but it only took about 10 seconds to reset the clock.. For us (lucky folks), the less expensive mechanical timer ($38) fills the bill perfectly.. ![]() |
#12 | ||
![]() The electritions that I know who don't like wiring up electric on demand hot water heaters are that way because they have complaints from customers, my boss installed one such water heater in his spare bath room, it called for a 80amp breaker and 4 gauge wire at a cost of over $2 a foot just for the wire, the heavier the wire the longer it takes to install so the higher the install labor cost as you can't just fish 4 gauge wire in a wall like you can with 10 gauge.
To me that is an issue of needing things to be idiot proof. Quote:
I'm still day dreaming about getting that self setting water heater timer put together, but all of my computer programmer friends have to much going on. One of my favorite on demand gas water heaters is more or less a 5 gallon tank water heater with a large burner and the tank is super insulated, draw back of course is that it's rather expensive, but unlike a lot of on demand water heaters, the water temp is very consistent. Last edited by Ryland; 09-06-11 at 09:45 AM.. |
#13 |
![]() Xringer...you seem real handy with electronics. Could you build a board to run say three water heater elements. You could use a flow sensing switch to turn on the power. Wouldn't just simple elements with the thermostat on them work, they would limit the water temp and as back-up you could use a tempering valve.
They look exceeding simple to make as far as tanks, plumbing. Would be a fun project I would think. Sometimes I wonder why the heck some things are so dang expensive. ![]() There are other pics higher end units and they are all of similar design. ![]() |
#14 |
![]() It looks like three high temperature cut-offs are in series with each of the three elements.
Those are easy to find and should be retained in a DIY heater.. That processor is the complicated part.. It seems like you could find an SSR Crydom Solid State Relay SSR H10D4850 50amp | eBay that could control heating elements. (Maybe one SSR for each element). This type of SSR can be switched with just about any digital controller. By turning the SSR on and off rapidly, you can control the power used by the heater. I'm not sure how those flow sensing switches work, but it seems like they are pressure activated. Might be hard to DIY one of those gizmos.. But, if you could buy a cheap flow sensing gizmo, G6 (3/4in) DC3-24V Water Flow Counter/Sensor | eBay (253 PSI).. ![]() I'm pretty sure you could use it to drive an SSR... Just about anyone with a little e-tech skill should be able to built the controls, for the plumbing shown in your picture.. When the cold water stops flowing to the heater, you would have to make dang sure the heater power stops too. Cheers, Rich |
