#391 | |
![]() Quote:
Even easier than the Sanyo is the homemade heat pump I already built... ![]() I just need to check it to see if it is still working. I was pretty low on the learning curve when I built it, and it may need to be re-charged. More soon... -AC_Hacker |
#392 |
![]() Congrats on the successful test AC Hacker! Thats a LOT of hard work validated.
#393 | |
![]() Quote:
#394 | |
![]() Quote:
And thank YOU for seeing this meandering odyssey through. ...but wait! There's more to come! (* ...to be continued... *) -AC_Hacker Last edited by AC_Hacker; 12-07-10 at 03:45 PM.. |
#395 |
Need More Eco
![]() But wont that require you installing pex in your floors, or am I missing something?
I sooooo appreciate your work on this project, I hope to do similar myself (but mostly for cooling) |
#396 | |
![]() Quote:
The reduced delta-T issue and heat pumps is at play when you do a ground source heat pump. It is also at play when you do a radiant floor. So, yes I have been planning to do a radiant floor all along. It's not going to be easy, because I live in a very old house and a two-inch thick concrete suspended floor is just not in the cards. But I am looking into ways of getting a high efficiency floor that doesn't weigh as much as two inches of concrete. Right now, I'm favoring a built-up floor made of layers of Wonderboard brand tile-backer board. I have done some preliminary tests on various materials and Wonderboard looks better than Durock and Hardybacker board. I have also done some experiments with unusually high thermal transfer aggregate for concrete, but so far, no love. Nevertheless I still think it has promise. AC_Hacker |
#397 |
![]() I remember now, sorry. The thread is long. I thought you had your floor loops installed.
I didn't see you mention how you were calculating your CoP in that graph. Can you explain it a little more as far as where your sensors were, etc. Also if you separated the data into different graphs I think it would be more accurate i.e. when you multiply your COP by 10 you also multiply error by 10. If you still have your original data I would be interested to see them separated and axes identified, I for one would find it much more informative. Last edited by pick1e; 12-08-10 at 08:22 PM.. |
#398 | ||
![]() Quote:
COP is energy out divided by energy in. You will need to capture the amount of energy going into your system.If you want specific assistance in setting up your own test, please tell me exactly what you need to know in order to proceed, and I'll try to assist. I wish you the best in your own project, don't forget the photographs. -AC_Hacker Last edited by AC_Hacker; 12-09-10 at 11:46 AM.. |
#399 | |
![]() Quote:
I would be neat to use your test results as a baseline comparison for my setup when I get there. But it's impossible to compare when I don't know what exactly you were testing. Looking at some dots on a graph doesn't tell me a lot if I don't know what it represents. I understand that "heat" and "chill" were temperature measurements of the two barrels. I have only guessed that "LS temp" and "HS temp" were readings at the heat exchangers, "HS press" and "LS press" were refrigerant pressures at the heat exchangers, and "super heat" and "sub cool" were measurements of the water leaving the exchangers but before mixing with the barrel water. And for COP I assume you were using a temperature approximation (Th/(Th-Tc) and not volumetric heat gain/loss, but I have no idea whether you were using the barrel temps or the heat exchanger temps or pre-barrel output temps, etc. If you could elucidate that would be helpful/informative. |
#400 | |||||
![]() Quote:
Ditto Super Heating. I derived values for Sub Cooling and Super Heating, to be used in system tuning. Since the only fine adjustment I could make was refrigerant pressure. I used an excessively high Sub Cooling value to discover that I needed to lower my refrigerant pressure. I did adjust that, and the efficiency increased accordingly. Quote:
Then COP = power-out / power-in I calculated this for each time interval. -AC_Hacker Last edited by AC_Hacker; 12-09-10 at 08:03 PM.. |
Tags |
air conditioner, diy, gshp, heat pump, homemade |
