03-15-15, 12:28 PM | #1 |
Land owner
Saving the world through increased consumption
Backyard burger and wiener roasts targeted by EPA | WashingtonExaminer.com
You just cant make this stuff up. From the article: "But, total capture isn't "practical," so a filter and fan are proposed for installation. "The secondary air filtration system is composed of a single pipe duct system which contains a specialized metal filter, a metal fan blade, a drive shaft, and an accompanying power system with either a motorized or manual method. This system can be powered by either an exterior electric motor with a chain-driven drive shaft, directly spinning the fan blade, or a hand-powered crank," said the project write-up." So now you will need to buy a grill with electric fan motor which needs to be plugged in, a chain drive, built in George forman style grease catcher and special metal air filter. What if you are camping and have no electrical power , then what do you do with the drippings if you are out some where camping? Keep them around, let them marinate in the sunlight for a few days or throw them on the ground and attract a bear? All great ideas, if you are on a bear hunting trip. |
