01-25-14, 04:49 PM | #12 |
We had colder than -20C and the indoor was set at 60F (I haven't changed the control to read C yet), the lowest it would go, which means the compression ratio must be close to max. I noticed a bit of oily stuff running from the flare nut down about 4' of the large tube, inside the insulation and a drip on the ground. I assume if there was enough pressure to push the oil out, some gas would also come out but I am not going to do anything like pump it down till it gets warmer. It is still heating and because there is only 5' of line set, I should have an excess of gas and oil as well.
It didn't show any leaks when the outdoor temps were around freezing. I just looked at the specs. The max running current should be 4.5A. Bummer. I better check as I may have bought a 1.5 ton unit (but I don't think so). Last edited by Mikesolar; 01-25-14 at 04:53 PM.. |
