07-28-13, 06:14 PM | #11 | ||
There was one guy on here named 'rhino' I think, who did trenches for cooling rather than heating (he lives in Florida). The reason I mention this is that he found out that his water table rises and falls. Therefore, the best time to dig your trenches is when the water table is at the lowest point, so you can achieve maximum depth and don't have problems with cave-ins. Randen did a trench system, I believe he went with straight pipes. Make sure you looked over his work. You'll also need to be aware of fluid friction and how it is affected by velocity, pipe diameter, pipe length, and viscosity (due to the possible presence and percentage of anti-freeze). Taco, the pump people have some good documentation on this. And of course, the IGSHPA Installation Guide has all this and much, much more. Best, -AC
Tags |
air conditioner, diy, gshp, heat pump, homemade |
