12-11-12, 02:09 PM | #11 |
Mikesolar,
Indeed, given enough coroplast the efficiency might be high enough. When just rotating whole plates 90 degrees you'll have surfaces that are not totaly flat pressed against eachother thus making a lousy contact with eachother. Not only will you have a double amount of coroplast between the cold and warm airstreams, they are separated with a thin layer of insulating air, this is not ideal. A while back I wondered why use coroplast at all? To me plastics aren't known for their great transfer of heat. But of course if it's a thin sheet with a large surface this is hardly a problem. Actual numbers: Coroplast 0.20W/m*K, Aluminum 237W/m*K I found a study where a HRV is build and tested with Coroplast, along with calculations. I replaced the value for coroplast with the one for aluminum in one of the formulas for -that- heatexchanger-core and the result changed from 12.7 W/m2*K to 13.2 W/m2*K, which is only about 4% higher for aluminum (if used in -that- specific HX). Link: http://www.ewp.rpi.edu/hartford/user...0Exchanger.pdf Last edited by Fornax; 12-13-12 at 03:24 AM.. |
Tags |
erv, heat recovery, hrv |
