Old 01-07-09, 07:41 AM   #1
jwxr7
jwxr7's Avatar
Default my diy pv set-up
Here are the 4 older solarex panels that I modified to work with a 200 watt grid tie inverter.
The panels started out life on the Oklahomah city library (so I'm told), and were 6 volt 70 watt utility grade polycrystaline pv panels. I traded a little electric scooter for them from a local alternative energy aquaintence. They are aged and probably only max out at around 60 watts. I tested them all in the fall one day, and they all worked within a watt of each other. They happened to put out in the lower 50 watt range that day with that load. I needed to convert them to 12 volts to be compatible with the inverter input voltage and current range. I did this with a little surgery. I split the panel electrically into 2 halves by cutting internal connections thru the silicone potting. Then I put these 2 halves in series to get twice the voltage and half the current as before. It was a success .
So I made a wooden rack and oriented it to true solar south in my field. I did this with a plum stake and observed the shadow at the sun's transit for that day and my location. The rack is also angled at the optimum winter angle for my area.
jwxr7 is offline   Reply With Quote
electric, solar
