Old 10-18-08, 07:09 PM   #1
SVOboy
SVOboy's Avatar
Default DIY: Waxing your Irish Linen Cue Wrap
Totally random, I know, but if you've got a pool cue with an Irish Linen wrap you may have noticed that it tends to get a little rough. At first, I was confused by this, but after a little research I learned that the trick was just to get some wax paper (like for cooking) and rub it vigorously around the cue. Do not rub it up and down across the wrap.
Do this until it heats and and you should transform your cue from this:
To this:
Hope someone out there finds this useful,
ID:	37   Click image for larger version
ID:	38   Click image for larger version
Old 10-22-08, 02:33 PM   #2
toyobug
avid DIY'r
toyobug's Avatar
cooooool! I have a buddy that could use this tip
toyobug is offline   Reply With Quote
